ᐅ What is the best way to secure IKEA PLATSA units to prevent them from tipping over?
Created on: 9 Mar 2024 18:27
Eltoklo
Eltoklo
9 Mar 2024 18:27
Hello everyone, I recently purchased the IKEA Platsa cabinet system and now I’m wondering about the best way to secure it against tipping, especially for taller modules or when placed on carpeted floors.
The furniture allows for flexible configurations, often quite tall and sometimes loaded asymmetrically. My main concern is that the risk of tipping should not be underestimated during use or in homes with children.
IKEA offers mounting kits, but I’ve heard that these can sometimes be insufficient. Are there alternative or additional solutions to ensure long-term stability? I would appreciate any experiences and tips you can share. I’m particularly interested in whether wall mounting alone is enough or if extra measures are advisable.
Mufato
9 Mar 2024 19:03
Attach directly to the wall. Use the IKEA panel holder and select appropriate wall plugs depending on the wall type. If there is carpet flooring, place underlay sheets beneath to prevent slipping.
RENMA
9 Mar 2024 20:12
Wall mounting is generally required for PLATSA, especially for taller structures over 2 meters (6 ft 7 in). The included brackets are standard, and their holding strength depends on the wall material. For drywall, it is recommended to use special drywall anchors or even better, cavity anchors. For solid walls, heavy-duty anchors are advisable. Additionally, floor-level stabilizers can be installed to improve stability, particularly on carpet. Proper installation using a level is also crucial to ensure even weight distribution.
Palenar
9 Mar 2024 21:45
RENMA schrieb:
Wall mounting is generally mandatory for PLATSA, especially for taller structures over 2 meters (6.5 feet).
I fully agree with this and would like to add some details. The PLATSA system modules are relatively easy to assemble due to their modular design, which has advantages but also poses potential stability risks. When it comes to wall mounting, the following steps should be taken:
- Determine the wall type before installation: concrete, brick, drywall, or plasterboard.
- For concrete or brick walls, use professional metal or plastic anchors with appropriate load-bearing capacity.
- For drywall, always use hollow wall anchors (e.g., molly bolts or toggle bolts), not just simple plastic anchors.
- In addition to the wall bracket, it is advisable to install cross braces or floor leveling adjustments if the surface is uneven.
- For added safety, the rear base rails of the modules can be permanently supported with non-slip material, such as rubber mats, especially if carpet flooring is present.
- If small children live in the household, cabinet doors should be secured with additional locks or safety devices to prevent tipping due to door load.
Technically, it is also important that rear fixings are always placed on load-bearing points whenever possible. Modules should be secured not only at the top but also in the middle if possible, to prevent vibrations.
U
usJamie
10 Mar 2024 08:14
Use wall brackets and anchors suitable for the type of masonry. Place an anti-slip mat under the cabinet on the carpet to prevent sliding. Otherwise, tipping over is rarely an issue.
flo-Theres
10 Mar 2024 10:32
For wall mounting IKEA PLATSA: In addition to the recommended installation using brackets, you should definitely check the load-bearing capacity of the wall. For softer walls (e.g., drywall), make sure to use appropriate cavity anchors to ensure full holding strength.
For carpeted floors, make sure the cabinet is not resting solely on the carpet, as this can reduce stability due to uneven support. In this case, support plates with a non-slip surface are helpful.
A good practice is to position the system as flush and fully against the wall as possible to minimize leverage forces from uneven loads. If possible, a second wall attachment can be placed in the center.
