ᐅ What installation spacing should be used for radiant floor cooling?
Created on: 19 Jan 2024 18:27
SandyBlack
I am interested to know if any of you are using underfloor heating with a cooling function and have a pipe spacing greater than 10cm (5 inches).
What has your experience been like?
What pipe spacing do you typically use?
I would appreciate your comments.
SandyBlack25 Jan 2024 09:02Why the 10 euro part?
It’s not about the additional valve but the hydraulic balancing valve (HBV).
If there is only space for 8 valves, we will need a larger HBV.
But good point – maybe I can get the larger HBV myself.
No, we are not installing solar thermal.
Daniel-Sp25 Jan 2024 14:13What other nice features will be installed then?
A mixing module does not bode well.
SandyBlack25 Jan 2024 14:14In what way? Could you please explain that?
To my knowledge, the Arotherm Plus 55/6, unistor hot water storage tank 300 liters (79 gallons), hydraulic station, and the 45-liter (12 gallons) buffer. In the living area, the sensocomfort 720.
Daniel-Sp25 Jan 2024 16:01A mixing valve is not necessary when the heat pump is connected directly to the heating circuit. For a combined storage tank, hygienic buffer tank, or separation buffer, a mixing valve is required. Now, the question is: what exactly is the mixing module?
SandyBlack25 Jan 2024 16:31As far as I know, we don’t have any of that...
What is a separation buffer?
We have a hydraulic separator – so a buffer in series, as far as I understand.
Daniel-Sp26 Jan 2024 14:23A buffer in series is not a hydraulic separator.
