ᐅ What does modern electrical wiring in a house involve? A practical example...
Created on: 2 Feb 2019 15:05
Mycraft
The topic of modern electrical systems keeps coming up, and many people feel uncertain or simply poorly informed.
Homeowners often ask themselves:
- Do I need this or not?
- Are the additional costs justified?
- What are the advantages?
- What are the limitations?
- What exactly is a smart home?
For this reason, I would like to share some of my experiences.
I have been living in an automated house with modern electrical systems for about 7 years now. Whether it is smart, automatic, or intelligent – I’ll let the reader decide. I will provide examples of how we implemented certain features to give an idea of what is possible. I would say our house is rather moderately automated, as I know of examples where much more has been done.
Smart homes / Modern electrical systems / Intelligent houses – all these terms somehow describe similar things, but everyone imagines something different. Especially if you have no background and have only ever known the usual: clap your hands or flip the switch → light on!
Every manufacturer who offers switchable outlets, motion detectors, and perhaps thermostats with a central controller calls it a smart home.
But that is not actually smart at all. At most, it just makes daily life a bit easier.
Because outlets with timers, lights with motion detectors, and a heating system that maintains or automatically adjusts the temperature are simply three different systems that can coexist side by side with central control and perform their tasks. Such helpers existed 30 years ago as well, but back then nobody called that a smart home.
Even adding a voice assistant doesn’t automatically make it a smart home.
If you want, you could call it an automatic house.
Smart homes, meaning “intelligent” houses, are much more than that.
It becomes “intelligent” when many systems and devices from different manufacturers are integrated so that processes interact and synergies emerge.
Functions can and must be customized to the specific needs and habits of the homeowners, taking the environment and external influences into account. Of course, all this should be economical, flexible, and easily expandable or modifiable at any time.
Seven years ago, we also faced the decision of which system to choose and considered many options.
What was important to us:
- No closed solutions, meaning no dependence on one manufacturer or cloud service
- Availability and variety of components
- Flexibility and scalability
- No batteries or additional adapters
- High reliability
- Future-proof design
- The ability to let multiple systems work together, not just alongside or against each other
- Costs
Discreet installation was especially important to us. We wanted the technology but as invisible as possible. It’s understandable that displays, switches, and presence detectors are more noticeable than regular light switches, but the rest of the system is hidden. There are no additional sensors glued or screwed onto windows or doors – only the end devices at the outlets.
Everything was implemented with KNX technology by a skilled professional and myself.
Currently, the house includes:
- About 100 outlets, around 30% of which can be switched individually
- 48 switchable channels in total
- 15 lighting groups, 8 of which are dimmable
- 14 roller shutters
- 2 built-in touchscreens plus other portable control devices (laptop, iPhone)
- Various temperature, gas, CO2, air quality, and light sensors
- 8 presence detectors
- 8 switches with displays, each with 3 rocker switches (6 buttons)
- 10 smoke detectors
- 30 LAN ports
- 8 IP cameras
- 8 satellite connections (for 3 TVs)
- 1 voice control system
- 1 weather station
Examples of our automation:
Shading, climate, ventilation, and heating control
To prevent overheating in summer while maximizing solar energy gain, these systems need to work together.
The heating system detects through indoor temperature sensors that heating is not currently necessary and circulates water in the floor to slightly maintain temperature because the weather station reports a warm day. Indoor and outdoor temperature sensors observe the difference and adjust the ventilation system to ensure air exchange but only dynamically suck in a minimum of warm outside air. The ventilation system detects air pollutants (e.g., from cooking) and filters odors as quickly as possible, deciding autonomously what action to take.
The shading system continuously adjusts the roller shutter slats to minimize heat gain without darkening rooms excessively to avoid disturbing residents. The weather station reports the current solar intensity on the sun-facing facades. As a last measure, the air conditioning is on standby and cools the rooms if thermostats signal a need. The air conditioning turns off when windows or doors remain open for extended periods. Hot water is heated and stored by solar panels.
When away or taking a nap, the house maximizes shading/darkening and minimizes ventilation. Other systems remain unaffected and maintain temperature and other conditions at the desired level. Presence, absence, and sleep are detected by additional sensors and reported to the systems.
In winter, everything works the opposite way. There is little shading to capture as much as possible of the sun’s “free energy.” Ventilation is continuously adjusted to current conditions. Windows generally remain closed. The air conditioning and summer bypass are off.
The system also detects when someone showers and increases exhaust ventilation to remove moisture quickly.
The system is calibrated enough for us to do without a separate energy recovery ventilator (ERV). Mostly, this is due to outdoor temperature-controlled boiler management and natural self-regulation rather than the advanced control itself.
Roller shutter control:
As mentioned, shading is a major part. Additionally, there are various scenarios, usually executed automatically but also manually triggered.
The roller shutters are continuously informed by sensors about the current situation, such as solar intensity, window position (open/closed/tilted), indoor and outdoor temperatures, and whether anyone is home. From this, the shutters calculate the optimal position.
For example, shutters open in the morning and close in the evening. It’s not simply about light or dark outside but also the time of day and the season. In winter, some shutters stay open longer in the evening to allow Christmas lights. They close only when residents decide to go to bed.
There is an extra safety mechanism at the patio door: as long as it is open, the shutter stays up. Generally, whenever a window opens, the shutter rolls up. Closing the window causes the shutter to lower again unless it is already light outside or shading is needed, in which case the shutter moves to the last used position. If the door is closed but people remain outside longer than a preset delay, another condition applies: as long as the patio light is on, the shutter remains up. This makes being locked out nearly impossible.
The advantage: you don’t have to worry about the shutters. They are always in the right position and require no manual intervention. If you want to go outside and the shutter is down, simply open the door.
Lighting and shadows:
In all non-living areas such as the kitchen, bathroom, hallways, etc., presence detectors switch lights on and off slowly or quickly depending on the situation and required lighting. Constant measurements determine current conditions and whether light is needed at all. Different rules apply during the day versus evening or night, adjusting brightness accordingly. The house “knows” when occupants are sleeping, so lights come on dimmed in the morning. Also, shutters in bedrooms stay down until a certain time during sleep, and the doorbell is disabled during that time.
Here you can see again how everything works together.
Since we have two cats, we couldn’t automate everything further and had to forgo popular presence detectors under the bed.
We also have predefined lighting scenes like cinema, dinner, or watching TV. These create lighting moods according to our preferences, for instance, dimming the room when the projector is turned on or activating subtle LED lighting while watching TV.
Hallways, entrance, utility room, and guest WC have small light switches. Everything runs automatically, guests manage easily, and explanations are rarely needed.
Extras:
Thanks to advanced electrical systems, we also have neat little features impossible with conventional wiring. For example, there’s a sensor in the mailbox that detects when mail arrives. The coffee machine in the downstairs kitchen turns on automatically in the morning (during a defined time) and makes fresh coffee.
Other small features:
- Presence simulation (a daily routine is mimicked, not just mindless on/off switching of lights)
- Alarm system (makes the house flash wildly in an alarm event)
- Motion alarms and doorbell notifications sent to phones
- Motorized lock
- Garden irrigation
- Central on/off control (at multiple points in the house and online)
- Various statistics and graphical displays of temperature trends, etc.
- Consumption measurements
- Leak detectors
- Individual socket power consumption with simple logic
- Garbage calendar with notifications for the correct bin the day before
- Visualization of the system and remote access
etc.
Why all this? Well, the reasons vary. First and foremost, it saves some time since you don’t have to operate light switches or shutters manually. Everything becomes a bit more convenient. You don’t need to perform five steps to watch a movie; just turn it on, and the house handles the rest.
It also provides a sense of increased security through status messages on the phone or presence simulation. Of course, it also saves some operating costs, which are then somewhat offset by the additional sensors and devices. Appetite grows with eating, and the system usually ends up getting expanded over time as new desired functions appear.
By the way, our system with about 80 participants/devices consumes a modest 20W of electricity. But there’s no end in sight – for Christmas, I bought a home server. Until then, a Raspberry Pi served as the gateway to the outside world and for visualization.
I probably forgot a lot, but that’s enough text for now, don’t you think?
Here are a few pictures to relax:
Yellow interior with airplane wall graphic and palm trees; door with pub lounge.
Bed with purple quilt; pink wall with the saying ‘The early bird can ...’, Mickey/Minnie plush toys.
Wall-mounted brushed metal housing with display of a ventilation system (exhaust, supply)
Wall-mounted metal panel with three horizontal sections and small display (date, room).
Time course from Jan 5–7 with lead time, room and outside shown as green areas.
Stefan890
15 Jan 2021 12:56
Mycraft schrieb:
Since it has been many years and I no longer want to maintain it, I switched to Home Assistant and am currently building the new visualization.
What are your first impressions so far? Do you maybe have a picture? I find the platform interesting as well and am considering switching. In addition, I am also using ioBroker. I might replace that too.
Mycraft schrieb:
Bosch Home Connect
I would like to integrate our oven. However, I haven’t looked into an API or anything like that yet. Do you have any experience with it?
I have had my MDT weather station for a year now. There was one occasion when no data was delivered (regardless of the sensor). After disconnecting the bus power, it started working again. Still, I fear it may not last forever, since it is constantly exposed to wind and weather.
Stefan890
15 Jan 2021 12:57
hippjoha schrieb:
And in my opinion, a very good application...
That's true, but you only really appreciate that after you've programmed a mediocre or bad application yourself :-D
Mycraft15 Jan 2021 15:33
Yes, that’s true. MDT is ahead by at least a couple of lengths compared to almost all the usual competitors. That’s definitely not to be underestimated. The best device is useless if it “can hardly do anything,” although for some, basic functions are enough since they delegate all the more advanced features to one or more other devices.
@Stefan890
Yes, the impression is good. It is quite simple and intuitive to set up and works practically right away. Bosch Home Connect can be integrated into the smart home via a developer account (but I’m just starting with that; for now it’s still operated here via the Google Hub).
As for the weather station, that’s not a given. Usually, these devices stay outside for decades and still function. Most likely, the plastic will degrade long before the electronics fail.
hippjoha
15 Jan 2021 17:26
Stefan890 schrieb:
True, but you only learn to appreciate that after you’ve programmed an average or bad application :-D
Oh yes, I recently struggled with a Meanwell power supply and its update... but that's another story...
I believe modern electrical systems aren’t just made up of a single system, but by their interaction. The main part for me is KNX, but it only becomes really good when I can integrate other sensors and react accordingly. Home Assistant (already mentioned and the one I use), ioBroker, openHab, etc. are truly great for that.
matte
15 Jan 2021 20:32
I am quite impressed with IP Symcon. I actually only use it to connect various systems with KNX (Sonos, Hue, Denon AVR, photovoltaic inverter), but that alone was worth the license for me. In the future, I plan to link a calendar to the bus for holidays and other purposes, such as roller shutter control and more.
Mycraft16 Jan 2021 12:27
No matter what you choose—Homeassistant, Iobroker, Openhab, IP-Symcon, or one of the many other options—it is essentially an interchangeable piece of software at the top level. Without an underlying infrastructure (so to speak, the nervous system), these tools are more or less limited in their capabilities.
Many of the described scenarios (including remote control, security, energy savings, and advanced automation) require going beyond the technology itself—for example, by using specialized multifunctional controllers, interface modules, and other devices. However, much of this can also be achieved with standard features or the right hardware. In the end, software solutions are just options to replace hardware and make capabilities more flexible. Unfortunately, this is often not necessarily simpler in terms of use and setup.
