ᐅ What is effective for removing scratches on Malm surfaces?
Created on: 9 Feb 2023 19:37
Gau58
Gau58
9 Feb 2023 19:37
I have a somewhat specific question regarding scratches on Malm furniture, especially those with the smooth, laminated surface often seen at Ikea. I would like to know what really helps to make scratches on Malm surfaces as invisible as possible or at least reduce their visibility.
I am mainly interested in proven home remedies, but also specially designed products or techniques that can be applied without further damaging the surface. It is not about deep cracks, but rather light to moderate scratches that affect the overall appearance.
Has anyone had experience with touch-up markers, furniture care products, or any tricks like polishing, waxing, or similar? How long-lasting are the results, and how much effort does the treatment require?
Thanks in advance for your tips and insights!
Layla
9 Feb 2023 20:15
Hello Gau58,
I completely understand your desire for a good solution to deal with the scratches. Especially with Malm tables or dressers, these small imperfections significantly affect the overall appearance, and you no longer enjoy the furniture as much.
Gau58 schrieb:
So it’s not about deep cracks, but mainly light to moderate scratches that disturb the overall look.
I have had good experiences with furniture repair markers specifically designed for laminated surfaces, as they match the color well. However, it is important to find the right shade – a slightly darker tone is better than one that is too light to visually reduce the appearance of the scratches.
Sometimes a combination of furniture wax and gentle polishing with a soft cloth can help. Avoid rubbing too hard, as this can further damage the surface. I know this may not be a perfect solution, but a little patience can make the scratches much less noticeable.
How deep are your scratches approximately? That makes a big difference in which method will actually be effective.
Tofra45
10 Feb 2023 08:52
Layla schrieb:
Sometimes a mix of furniture wax and a bit of polishing with a soft cloth helps.
Furniture wax is really the best option for minor scratches on Malm. Just apply a thin layer and polish with a microfiber cloth.
For deeper scratches: use touch-up pens or markers available in matching colors. For Malm, a light beige or white often works well.
kasan
10 Feb 2023 10:37
I want to look at this issue from a somewhat more critical perspective.
Tofra45 schrieb:
For deeper scratches: paint pens or markers, which are available in matching colors.
Such products can improve the appearance, but they do not solve the structural problem of the surface. Since chipboard is usually a laminated panel, the material damage often remains noticeable despite refreshing the color and can potentially lead to further wear if the furniture is used frequently.
Additionally, you should make sure that the products do not contain aggressive solvents that could damage the laminate.
An alternative, if possible, is to replace the damaged laminate or, for small areas, to use a specialized repair kit designed for laminate surfaces, which also replicates a minimal surface texture.
What are your experiences with this? My concern is that quick fixes only serve to conceal the damage and do not provide a sustainable long-term result.
JONSON
11 Feb 2023 16:46
As a supplement, I would like to offer some practical tips that can help when treating scratches on Malm surfaces.
First, the key question is how deep the scratches are. For light scratches or signs of wear, I recommend a gentle polish using a special plastic or furniture lacquer polish. These products slightly fill in micro-cracks and reduce their visibility.
kasan schrieb:
An alternative, if possible, is to replace the damaged foil or, for small areas, use a suitable repair kit specifically designed for foil surfaces
That’s a good point. Ikea uses a melamine or plastic foil on Malm furniture, which can be replaced in the worst case. However, this is only an option for more extensive damage.
Regarding touch-up pens, it is important to ensure that they actually adhere well to plastic foil – there are different qualities available. Testing on the backside or in an inconspicuous spot is advisable.
In summary: products like furniture wax and polish for light scratches, touch-up pens for color correction, and repair kits for foil surfaces can all help depending on the depth of the damage. It is also important not to apply too much pressure when polishing to avoid causing further damage.
