ᐅ What helps with discolored cabinet surfaces?
Created on: 15 Jun 2024 08:23
axelsau
axelsau
15 Jun 2024 08:23
Some time ago, I started using a number of Billy bookcases from IKEA at home. I have noticed that over time, the surfaces of the shelves and outer parts have developed noticeable discoloration – in some places, yellowish or brownish stains appear, while other areas look duller and somewhat darkened.
My question to you is: What methods have you found effective for removing or at least significantly reducing these discolorations on Billy bookcase surfaces? I would like to try anything gentle enough to avoid further damage to the surface, as it is a coated particleboard.
I am especially interested in any recommended household remedies or specific cleaning products. Additionally, I would appreciate any tips on how to prevent such discoloration from occurring in the first place.
Thank you in advance for your help!
gasidney
15 Jun 2024 09:04
Hello, for discoloration on Billy surfaces, I recommend using a mild dish soap and a soft microfiber cloth. Stubborn stains can often be removed with a bit of isopropyl alcohol, but be careful not to damage the surface.
benon
15 Jun 2024 10:15
Hello axelsau,
I think your question is very important because many people underestimate the issue of surface discoloration. The Billy shelves are made of particleboard with a melamine coating, which is quite sensitive to aggressive cleaning agents.
Home remedies like vinegar or gall soap can theoretically help, but I recommend testing them first on an inconspicuous spot.
A good method is to use a mild cleaner such as dish soap and lukewarm water. If you use vinegar essence, dilute it strongly—for example, 1 part vinegar to 10 parts water.
Lemon juice can also help with discoloration but should be used carefully, as the acid can damage the surface.
For prevention: try to avoid direct sunlight exposure, as UV radiation can discolor the coating. Also, make sure not to place hot or wet items directly on the surface.
Kinbu
15 Jun 2024 11:33
I can only agree with that. I have personal experience with Billy shelves and found that especially greasy residues and dust can cause discoloration.
Usually, a slightly damp cloth is enough to wipe these away. However, I recommend avoiding highly pigmented cleaning agents.
If stains are already present, you can try using a surface eraser; it is often surprisingly effective and gentle.
klo61
15 Jun 2024 12:49
I would like to add that discoloration can sometimes also be caused by contact with certain materials – for example, pressure from colored papers or pens.
axelsau schrieb:
I would like to try everything that is gentle enough not to damage the surface further
That is a very important point. I always recommend avoiding abrasive cleaners and harsh solvents, as they can make the surface dull and roughen it.
A special furniture care product designed for laminate surfaces might also help, as it both protects and cleans.
Regular maintenance every few months is also beneficial, as it prevents dirt from settling in the first place.
Joe52
15 Jun 2024 14:07
I completely understand what the discoloration issues mean; I had a similar problem years ago with my Billy shelves. It can be really frustrating because the shelves are otherwise great.
At first, I didn’t take that advice seriously, and afterwards, the surface became almost rough.
I then started using special furniture care sprays that also have slight covering properties, which significantly improved the appearance. Maybe someone wants to try that 🙂
One tip from me: definitely avoid placing flower pots with soil directly on the surface, as this quickly leads to stains.
