ᐅ What helps with squeaky doors on Billy bookcases?
Created on: 29 Apr 2023 08:37
permin
permin
29 Apr 2023 08:37
I have noticed that the doors of several of my Billy bookcases creak unpleasantly when I open or close them. The furniture is no longer brand new, so it is probably due to wear or an improper adjustment of the hinges.
My question is: What specific measures can be taken to achieve a lasting improvement or solution for creaking doors on IKEA Billy furniture? I am thinking of lubricants, readjusting, or possibly replacing certain parts. What should I pay particular attention to?
I look forward to your tips and experiences so I can fix the problem permanently!
SUBEN60
29 Apr 2023 09:12
Squeaky doors on Billy furniture are often caused by friction on the metal hinges or mounting points.
1. First, I recommend checking the hinge screws and tightening them if necessary, as loose fittings can increase vibrations.
2. For lubrication, specially formulated Teflon or silicone sprays are suitable because they do not attract dust.
3. Avoid using WD-40 permanently, as it leaves oily residues that attract dirt.
4. If in doubt, the hinges should be inspected for wear and, if needed, replaced with original spare parts.
These steps usually result in a lasting reduction of the squeaking.
INGRID34
29 Apr 2023 09:45
I simply sprayed some silicone spray on the hinges of my Billy doors. After that, they were quiet again. It is important to apply the spray sparingly.
KUDAISY
29 Apr 2023 11:08
Regarding squeaky doors on Billy furniture, here is a more detailed guide:
1. Analysis: First, check exactly where the squeaking occurs. It is usually caused by the hinges, but sometimes poorly fitted wood components or the door itself can be the reason.
2. Cleaning: Dust and dirt in the hinges contribute to the noise. Thoroughly clean the hinge with a small brush or cloth.
3. Adjustment: The screws on the hinges often allow you to move the door slightly up, down, or sideways. Incorrect alignment can cause friction and squeaking.
4. Lubrication: Lightly apply a suitable lubricant – I recommend silicone spray or a special hinge oil – to the metal moving parts. Never use too much, as this can attract more dirt.
5. Check: After lubricating and adjusting, open and close the doors several times to allow the materials to “settle.” The noise should be noticeably reduced.
6. Replacement: If the hinges are heavily worn, sometimes the only solution is to replace them with new original parts.
Common mistake: Using too much lubricant, which causes dirt buildup. This can worsen the problem over time.
I hope these steps help. If anyone has specific issues with the plastic base parts of the hinges, I can provide advice on that as well.
permin
29 Apr 2023 12:30
KUDAISY schrieb:
Typical mistake: Using too much lubricant, which attracts dirt. This can make the problem worse over time.
That makes sense to me. I had that issue a few weeks ago with another door—I used too much oil, and later there was more dirt on it than before.
How often would you recommend renewing lubrication on Billy doors if there is no initial squeaking? Is this something you should check annually, or does lubrication typically last much longer?
TAUFA
29 Apr 2023 13:15
I would say: Checking twice a year is enough. You can simply apply a light lubricant when you notice noises again or the doors start to become a bit stiff. That is usually the best approach.
