ᐅ What can you do if Ikea Hemnes doors are squeaking?
Created on: 14 Apr 2024 19:37
Clyde38
Clyde38
14 Apr 2024 19:37
Hello everyone, I am looking for effective methods to eliminate the squeaking of the doors on my Ikea Hemnes wardrobe. The noise mainly occurs when opening and closing, which could indicate worn or poorly lubricated hinges. I have already tried tightening the screws, but that only helped temporarily. Does anyone have experience with this specific type of furniture and can offer advice on which products or techniques really help to permanently stop the squeaking? I am especially interested in recommendations for suitable lubricants and any routine maintenance that can be done as a preventive measure. Thanks in advance!
Filippo
14 Apr 2024 20:05
Hello Clyde38,
First of all, a clear description of the issue you’re experiencing. The squeaking on Ikea Hemnes doors is often caused by friction in the hinges, usually because lubrication is missing or contaminated. There are a few steps I recommend to address this systematically:
- Loosen screws and remove hinges: On Ikea Hemnes furniture, hinges are usually attached in two ways, one set of screws on the inside of the door, and another on the cabinet side.
- Clean hinge components: Old lubricants can become sticky or dried out. A lint-free cloth with some isopropyl alcohol works well to clean the area.
- Lubrication: A thin, durable lubricant is typically used. I prefer a silicone spray for door hinges because it doesn’t become sticky and repels dust. Alternatively, a Teflon-based oil can also be used.
- Reassembly and adjustment: After reinstalling the hinges, carefully align the door so it doesn’t stick or hang crookedly—this can also cause squeaking.
One more question: Are your hinges adjustable (Hemnes doors often have quick-adjust screws), or are they fixed hinges? This will affect the procedure.
Additionally, you can check the door edges and seals for wear, as sideways pressure can sometimes cause noise. If you like, I can provide you with a step-by-step guide for removing and reinstalling the hinges.
CHENFAR
14 Apr 2024 20:22
As a supplement, the most common causes of squeaking doors in Ikea Hemnes furniture are:
- Insufficient or gummy lubrication of the metal hinges
- Doors that are warped or misaligned, causing friction at the hinges due to tension
- Dirt (dust, lint) inside the hinge mechanism
Here are some practical tips to solve the problem:
- Use graphite or silicone spray for lubrication, as these substances do not attract dust
- After lubrication, move the hinges several times to distribute the lubricant evenly
- Check whether the doors are properly aligned. Incorrect vertical installation causes additional mechanical stress
The easily accessible Hemnes hinges usually allow adjustment via screws on the hinge. By slightly loosening the screws, the door can be repositioned with gentle pressure, ensuring that it still closes flush.
In short: cleaning, lubricating, and correct adjustment are the three key steps to stop squeaking.
Jensson
15 Apr 2024 08:13
I would like to share a simple step-by-step guide that has worked very well for me to fix squeaky Ikea Hemnes doors.
1. Preparation: Open the hinge and visually inspect for dirt, rust, or wear.
2. Removal: Loosen the screws on the hinge plate and carefully take off the hinge.
3. Cleaning: Clean all moving hinge parts with alcohol and a cloth to remove old lubricant and dirt.
4. Lubrication: Apply a thin layer of silicone oil or an appropriate Teflon oil to the hinge pins. Please avoid WD-40 or other penetrating oils, as they attract dust.
5. Reassembly: Reinstall the hinges and gently adjust if necessary to ensure even door movement.
6. Test: Open and close the door several times to make sure the squeaking is completely gone.
A common mistake is using lubricants that are too thick and cannot penetrate the narrow hinge pins. For optimal lubrication, the product should flow easily.
If anyone needs more details about adjustment or the specific Ikea hinge types, just ask!
Filippo
15 Apr 2024 10:47
Jensson schrieb:
Please avoid using WD-40 or other penetrating oils, as they attract dust.
I fully agree with you, Jensson. Although the short-term effect of WD-40 can be appealing, it often causes dirt to build up over time, which tends to make the squeaking worse. Silicone sprays are ideal for hinges because they do not become sticky and provide good lubrication without attracting dust.
An important addition to my previous answer: If the squeaking persists despite lubrication, it is worth checking whether the hinge pins themselves have slight rust. In that case, gently sanding them with very fine sandpaper (e.g., grit 600) before cleaning and lubricating can help.
One more question for Clyde38: Are you using the Ikea Hemnes cabinet in a more humid environment (e.g., kitchen or bathroom)? Sometimes moisture promotes rust formation, which causes the noise.
In summary, I recommend:
- Removing and thoroughly cleaning the hinges
- Checking for rust
- Using silicone spray or Teflon oil
- Adjusting the door
In my experience, this careful approach provides the best long-term solution.
Ramon4
15 Apr 2024 14:29
For anyone who might be new to this kind of repair: don’t be afraid to remove the doors! With Ikea Hemnes cabinets, the hinges are designed to be relatively easy to detach, often featuring a small lever or clip.
Here’s a practical tip for lubrication: if you don’t have professional silicone spray on hand, ordinary sewing machine oil can be used as a temporary solution. It’s very thin, attracts less dust, and works well on moving hinge parts. This can help in the short term until you get the proper material.
Also, remember not to put excessive strain on the furniture for at least a day after lubrication to allow the oil to distribute well within the hinges.
If you discover that one of the doors is warped, you can improve the fit by using wooden wedges or small washers on the hinge mounts. This helps reduce mechanical binding.
It’s definitely worth the effort, as squeaky or creaky doors can become very annoying over time.
