ᐅ What can I do if the handles on my Ikea Besta units are broken or loose?
Created on: 21 Oct 2024 08:47
lenhau
lenhau
21 Oct 2024 08:47
I have an issue with the handles on my Ikea Besta sideboard: they are either completely broken or at least so loose that they can hardly be fixed anymore. I suspect this is due to the material quality or prolonged use, but I don’t want to just do a temporary fix – I’m looking for a durable repair or replacement.
My question is: What specifically can help when the handles on Ikea Besta furniture are broken or loose? Are there suitable replacement parts that hold well? How can I best attach the handles if the screw holes have become worn out? And is it worth switching to different types of handles?
I would appreciate experiences and practical tips, especially on how to achieve long-term stability without damaging or making the furniture worse.
Thanks in advance!
Dilen
21 Oct 2024 09:15
Hello lenhau,
I would like to address your issue with broken or loose handles on Ikea Besta furniture in more detail, as this is a common area where mistakes and pitfalls occur if the problem is only approached superficially.
First of all, the problem with worn-out screw holes is typical for furniture made from particleboard or MDF panels, which are often used by Ikea. Over time, the material degrades if screws are repeatedly inserted and removed or if the handles are constantly under stress.
A few repair tips:
- Replacement handles: Ikea offers some replacement handles that are compatible with the existing mounting. It’s best to check Ikea’s website or store directly to find a matching handle, as the hole spacing is standardized.
- Hole reinforcement: If the holes are worn out, screws can’t be tightened properly. I recommend repairing with wood dowels or wood filler. You can initially fill the holes with wood putty, then reinforce them with a dowel or a small wooden stick, and finally screw the handles back in. This holds much better than just tightening the screws.
- Alternatively: Metal inserts or so-called “threaded inserts” can help stabilize the screw thread. However, this is a bit more complicated and requires drilling from the inside of the furniture.
If you want to completely replace the handles and switch to other models, be sure to measure the hole spacing (usually 128 mm or 160 mm (5 inches or 6.3 inches) for Ikea). Handles with the same spacing will fit without problems.
Last but not least: If the handles are broken, it could also be due to the material. Some plastic handles do not last very long – in that case, it’s worth choosing a metal handle, which is more durable.
One quick question: Are these handles screwed in from the front, or are they push-to-fit or recessed handles? This changes the repair method slightly.
I hope this helps you for now. I’m happy to provide more detailed advice on individual steps if needed!
ju_ren
21 Oct 2024 10:27
Dilen schrieb:
If the holes are worn out, you cannot tighten the screws properly. I recommend a repair using so-called "wooden dowels" or "wood filler."
That’s exactly how I did it. First, fill the holes with wood filler, then insert dowels and use new screws. It has held up for me for years.
Kinbu
22 Oct 2024 14:53
Hello lenhau and everyone else,
I’d like to add a few points based on my own experience with Ikea Besta handles.
First of all: It’s quite normal for standard handles to either break or become loose after years of use. Most Ikea Besta furniture comes with plastic handles, which are not designed to last forever.
- Getting replacement handles: If you want the original look and feel, you can check the Ikea online store for replacement handles specifically for Besta. These are usually cheaper than full metal handles and fit perfectly, but they are often made of plastic.
- Better materials: Otherwise, I recommend choosing handles made of metal or sturdy aluminum. You can usually adapt them to the same hole spacing (typically 128 mm (5 inches)) since Ikea keeps this standardized.
- Loosening due to worn holes: This is a common issue when the screws no longer tighten properly. One option is to stabilize the holes with some superglue or wood glue, then immediately screw in the screw so the glue sets. Be careful not to use too much, or the threads may stick.
- Alternatively, a so-called “screw eccentric” or “bridge plate” can help, which you screw inside on the back panel to anchor the handle more securely.
- If the handles on the furniture are damaged, you might also consider installing completely new handles that are a bit more robust and possibly even improve the look.
- For loose-fitting handles, wrapping the screw with Teflon tape (from plumbing) before screwing it in can help improve the hold.
This isn’t a high-end solution, but I find that the handle will hold for years again with reasonable effort. If you like, I can also give you tips on how to remove the handles if your cabinet is assembled differently.
Good luck!
