ᐅ What helps stop Malm beds from squeaking?
Created on: 16 Nov 2019 21:37
Tata56
Tata56
16 Nov 2019 21:37
I have a Malm bed from Ikea that has unfortunately been squeaking for a while when moving it. The noise mostly seems to come from the slatted base or the frame, but I’m not entirely sure. Since I use the bed every day, the squeaking is quite annoying and also disturbs my sleep.
I would like to understand what the most common causes of this squeaking in Malm beds are and how to best fix it. Are there specific areas where I should start looking? What tools or home remedies can be used to make the bed quiet again?
I’m also interested in whether there are long-term solutions, possibly special screws, dampers, or lubricants recommended for wooden beds like the Malm that won’t damage the material.
Has anyone had experience eliminating these squeaking noises in Malm beds or similar models? I’m looking forward to helpful and detailed advice!
Thanks in advance!
pauPierce
16 Nov 2019 22:11
Hello Tata56,
First of all, it’s good that you described your issue in such detail. This makes giving advice much easier.
Typically, squeaking in beds like Malm occurs mainly in two areas: at the joints between the wooden parts and at the slatted frame, which can sometimes include metal components.
A proven approach to solving the problem would be:
1. Tighten the screws: Especially with wooden beds, the screws tend to loosen over time due to movement. This causes slight movements and thus squeaking. Make sure to systematically check all screws, corner brackets, and any metal fittings.
2. Treat the connection points: Often, gently applying a dry lubricant such as paraffin wax or beeswax to the contact surfaces of the wood parts helps. I would not recommend silicone oil or WD-40, as these can damage the surfaces over time and are less suitable for wood.
3. Check the slatted frame: Screws or hook mechanisms on the slatted base can also loosen over time. It’s also possible that the slats themselves are under excessive strain and causing the noise.
4. Use rubber or felt pads: Some users place small felt or rubber pads between the support points to reduce friction.
Are the squeaking spots more at the frame or rather at the slatted base? It would help if you carefully try to identify the exact spots by applying pressure to different areas of the bed and observing.
Tata56 schrieb:
I would like to understand what exactly are the most common causes of this squeaking in Malm beds
How did you assemble the bed so far? Do you have the original screws and connections, or have any modifications been made? If you like, I can prepare a detailed step-by-step guide for inspection and targeted treatment.
Best regards, pauPierce
RENMA
17 Nov 2019 08:46
Good morning,
a structured approach to eliminating squeaks in Malm beds includes the following key points:
1. Locating the noise source: This is best done under load by applying targeted pressure to individual parts while simultaneously testing for noise generation.
2. Checking all screws and fasteners: Loose screws should be tightened using the appropriate tool (usually an Allen key). Care must be taken not to overtighten and risk damaging the threads.
3. Avoiding moisture contact when using lubricants, as wood swells when damp, reducing stability.
4. Suitable lubricants: These include dry waxes (e.g., beeswax) or furniture waxes specifically designed for wood. Silicone sprays are less suitable for wood.
5. If available, inserting rubber buffers at friction points to mechanically reduce noise formation.
6. Inspecting the slatted frame: Pay particular attention to metal stop points or flexible slats to ensure they are securely fastened.
pauPierce schrieb:
Retightening screws: Especially with wooden beds, screws tend to loosen over time due to movement.
This is usually the primary cause. The manufacturer’s warranty should also be considered if the bed is still relatively new.
Recommendation: Start by carefully retightening the screws and then observe whether the noise persists.
Regards RENMA
COLEBAR
17 Nov 2019 12:03
here are my practical tips:
1. Retighten all screws once.
2. Rub contact points with furniture wax or beeswax.
3. Check the slatted frame for any loose slats.
4. Avoid using oils or sprays on wood whenever possible.
This has worked for me for years without any problems.
