ᐅ What helps prevent paint from peeling on painted furniture made of MDF?
Created on: 12 Dec 2015 08:17
TatsuoHello everyone,
I have an issue with some of my Malm furniture from IKEA. The paint is peeling in some areas, especially along the edges, and it just looks unattractive. I suspect this might be related to the surface coating, but I’m not sure whether it’s mainly due to the material quality or environmental factors.
My specific question is: What can I effectively do to prevent paint from peeling on Malm furniture? Are there particular surface treatments, paints, or repair methods that work especially well? And how can I avoid the paint peeling again in the future?
I have already tried lightly sanding the peeled areas and repainting them, but it usually doesn’t last long. I’m grateful for any tips! Thanks in advance!
Hey Tatsuo!
It’s great that you’re taking such a detailed approach to your problem! :-)
I had a similar issue with a Malm cabinet, and what really helped me was a thorough cleaning using a solvent (be careful: test it first in an inconspicuous spot!) followed by fine sanding of the affected areas. Then I used a high-quality acrylic paint specifically designed for furniture. It’s important to apply the paint in thin layers and let each layer dry completely.
The key is really patience and the layers! If you also apply a clear protective coat afterward, it usually lasts a long time. Good luck, you can do it! 🙂
Pome60 schrieb:
The key truly is patience and the layers!Interesting approach, but it’s also important to consider why the original paint is peeling in the first place. Often, the issue is poor adhesion—either because the surface wasn’t properly prepared or because low-quality paint was used.
You mentioned sanding and cleaning, but have you also looked into the specific composition of the Malm furniture? The surfaces are often melamine-coated, which makes it difficult for paints to adhere. In my experience, you can only achieve lasting results using a special adhesion primer or even vinyl repair.
Additionally, it’s important to keep in mind that moisture and temperature fluctuations can have an impact. What is your living situation, and how much are the furniture pieces exposed to environmental factors, tatsuo?
ONRONA schrieb:
Surfaces are often melamine-coated, which makes it difficult for paints to adhere.This is a crucial point. Malm furniture is usually made of particleboard with a melamine surface, which is extremely smooth and hard. That’s why regular paint peels off very quickly without proper priming.
My advice: Before painting, lightly sand the surface with fine sandpaper (grit 240 or higher). Then apply a special adhesion primer designed for melamine-coated surfaces. After that, you can use a high-quality acrylic paint.
Avoid solvent-based paints, as they can damage the melamine coating. Another layer of protection would be a clear furniture varnish that is scratch-resistant and provides UV protection – this will help the paint last longer.
If you want to know more about this topic, just ask.
