ᐅ What solutions have you implemented in the area behind the radiators?
Created on: 30 Jan 2014 20:22
myckraft-1
30 Jan 2014 20:22
we are planning a heating system renovation in our older house, which we bought as a used property. The previous owners wallpapered behind the old radiators, so today it is no longer possible to access that area without completely removing each radiator. Now I would like to take the opportunity to install a long-lasting solution behind the radiators.
How have you dealt with this issue?
After all, wallpapering probably happens more often than replacing radiators.
If I have posted in the wrong forum, please feel free to move this.
Thank you very much in advance and best regards
Marie-1
1 Feb 2014 10:48
We also have wallpaper on ours.
I don’t personally like it that much, but it’s not something you can easily change.
Since you’re already removing all the radiators, maybe oil-based paint would be a good option. There is also special radiator paint available.
For better insulation, aluminum foil might help, but I’m not exactly sure how it affects heat transfer. It shouldn’t catch fire, though.
Since the heat is then radiated, the radiator might actually heat more efficiently.
Marie
Robert-1
18 May 2014 09:29
Usually, wallpaper is installed behind the radiator. However, oil-based paint is also a good alternative and lasts longer than wallpaper. This oil-based paint is also available in radiator colors.
Louis-1
5 Sep 2014 15:51
I have an oil panel behind the radiators, and it is the same size as the radiator. It is also easy to clean.
sarahlein-1
19 Sep 2014 19:36
For us, it is also a standard wallpaper that looks anything but attractive.
sarahlein-1
19 Sep 2014 19:36
The problem is that it is difficult to reach there, so it’s better to remove the radiator...
