ᐅ What are your experiences with the mattresses for the Ikea Hemnes bed?
Created on: 15 Feb 2022 09:37
IsaiahnauI
Isaiahnau15 Feb 2022 09:37Hello everyone, I have been considering buying the IKEA Hemnes bed for some time now, as the design and storage options seem really appealing. However, I am still unsure about choosing the right mattress because there are different types that vary significantly in material, firmness, and comfort.
I’m especially interested in hearing about your experiences with mattresses you have used specifically for the Hemnes bed from IKEA.
I’m curious about both subjective impressions such as comfort, sleep quality, and durability, as well as more objective factors, for example, whether the bed frame tends to make noise with certain mattresses, how ventilation performs, or if it’s better to go for a more flexible or a firmer mattress.
Additionally, do you perhaps have any recommendations on which mattress models work particularly well with the Hemnes or which ones are better to avoid?
Thank you in advance for your detailed feedback!
Hello Isaiahnau,
first of all, an important note: The IKEA Hemnes bed already has a fairly sturdy slatted bed base that is compatible with most standard mattresses. However, the choice of mattress should primarily depend on your own sleeping habits and body weight, as the Hemnes is not an adjustable bed frame and therefore does not require special features regarding flexibility or suspension.
I personally used a high-quality foam mattress (from the IKEA range) in combination with the Hemnes about two years ago. It is important with these beds that the mattress is breathable, since the Hemnes has slatted bed bases and no continuous solid base. This ensures better air circulation, which in turn extends durability, especially for foam mattresses.
I find the accurate matching of firmness level crucial: For someone weighing around 80kg (176 lbs), a medium firmness (for example, H3) is advisable. For heavier individuals, firmer options should be chosen to prevent the mattress from sagging quickly.
I would rather not recommend a spring mattress—at least not the cheaper models—because they tend to vibrate more and can transmit noise through the frame. The Hemnes frame is made of solid wood, which reduces noise somewhat, but with a spring mattress squeaking or creaking can still occur.
If you are very sensitive, I would also suggest trying a separate topper to further customize the feel.
One more question: How often do you usually replace your mattresses? That often has more influence on the decision than one might think.
Leonardteo15 Feb 2022 12:41Based on my experience, I can add the following:
In my opinion, a medium-firm foam mattress fits best with a Hemnes bed, since the bed comes with a slatted frame. If the slatted frame is adjusted too softly, a firmer mattress is recommended.
This combination provides proper pressure relief and prevents sagging of both components.
When purchasing, it is essential to pay attention to the mattress’s foam density—it should be at least 30 kg/m³ (1.87 lb/ft³), with 35-40 kg/m³ (2.18-2.49 lb/ft³) being ideal, as this reflects quality and durability.
Unfortunately, some users report that very inexpensive mattresses noticeably lose support after just a few months—this is a common issue with budget models in the IKEA range.
I have never experienced the bed frame itself as a source of noise when paired with different mattresses; it has always been inconspicuous.
For those who prefer a firmer sleep surface, I recommend the IKEA Morgedal mattress, as it is slightly firmer and pairs well with the Hemnes bed.
Hey Isaiahnau!
I love my Hemnes bed and paired it with the "Morgedal" mattress from IKEA – I sleep really well on it!
Many friends told me to focus on comfort and breathability, and that’s exactly what the Morgedal offers: it’s neither too soft nor too firm, you don’t sink in too much, nor do you lie too hard. It also feels pleasantly cool, which I really appreciate in the summer.
The storage space doesn’t wear out from the mattress, the base underneath is sturdy – so no worries, the bed stays solid and stable.
At first, I noticed a slight plastic smell from the mattress, but that went away after a few days.
Highly recommend it from me, just be sure to try it out if possible!
Isaiahnau16 Feb 2022 08:52Laukau5 schrieb:
I would generally not recommend an innerspring mattress – at least not the very inexpensive models – as they tend to vibrate more and can transfer noise to the frame.Thanks for the tip! Could you explain the noise issue with innerspring mattresses in a bit more detail? I have slept on one before, but not on a wooden frame like the Hemnes. I rather had the impression that innerspring mattresses often conform better to the body.
Leonardteo schrieb:
If someone prefers a firmer sleep surface, I can recommend the IKEA Morgedal, as it is designed to be a bit firmer and works well with the Hemnes.Interesting – so the Morgedal offers a firmer comfort level. Can you also share something about its durability, especially regarding the material composition?
In terms of sleeping habits, I prefer a medium-firm firmness to avoid pressure points, but I also pay attention to ventilation since I tend to sweat quite a bit at night. Washability and easy care of mattress toppers and covers would also be a plus.
Does anyone have experience with moisture regulation in the various IKEA mattresses?
edisondan16 Feb 2022 10:14Basically, the ventilation in slatted bed bases like the Hemnes is significantly better than in box spring beds or beds with solid foundations. From a technical perspective, the slatted frame allows for regular air circulation under the mattress, which helps prevent mold growth and reduces pressure points.
When it comes to moisture regulation, much depends on the mattress topper – materials such as open-cell cold foam or latex allow for better evaporation than conventional HR foam.
Regarding durability:
- The "Morgedal" mattress is largely made from polyurethane foam, which is mechanically reliable but ages at an average rate. One aspect often overlooked is that the long-term load-bearing capacity of foam mattresses mainly depends on the foam’s density.
- For the medium firmness level you mentioned (H2-H3), I recommend foam densities of at least 35-40 kg/m³ to maintain support over the years.
On washability: Many IKEA covers are removable and washable, which greatly facilitates hygienic care. For moisture absorption and wicking, blankets and covers with moisture-wicking properties are worthwhile.
In summary: From my perspective, there is no conflict between comfort, hygiene, and ventilation as long as mattress, slatted bed base, and cover are well matched.
