ᐅ What are your experiences with assembling the Ikea Brimnes furniture?
Created on: 13 Nov 2024 08:37
Iliasken
Good morning everyone, I’m planning to assemble a new Brimnes bed from Ikea in the next few days and would like to gather your experiences and tips in advance. Specifically, I’m interested in how easy the model was to assemble for you, whether there were any challenges during the build, and how sturdy the bed is for everyday use. I’m especially looking for advice regarding tools, the assembly instructions, and any potential issues with the drawers, which are known to be a bit tricky. Are there any improvements or tricks you would recommend? I appreciate all feedback, whether positive or negative!
neoren
14 Nov 2024 11:44
Briefly about tools and procedure: A Phillips screwdriver, a cordless drill with low torque, and a small hammer (for the wall plugs) are sufficient. Sort the parts and follow the instructions step by step—these are the most important points. Align the drawer slides precisely, otherwise they will stick.
nubar
14 Nov 2024 14:33
KAULIS schrieb:
The assembly instructions are generally easy to understand, but I recommend unpacking and sorting all parts completely before starting.
I did exactly that and can confirm this step saves a lot of effort. Additionally, I suggest checking the supplied screws for completeness and condition. Occasionally, small parts were missing or damaged — in that case, it’s better to promptly get replacements before assembly is delayed. Also: be careful not to tighten the screws with full power from the cordless drill; instead, hand-tighten them gently. This helps prevent the material from cracking.
Jensson
15 Nov 2024 07:57
Here is a brief guide based on my experience assembling the Brimnes bed: 1. Lay out all the parts on the floor in an organized way to avoid wasting time searching for pieces. 2. Pay special attention to the side panels, ensuring all holes and dowels are properly aligned; otherwise, the frame may bend later. 3. Assemble the frame first without fully tightening the screws. 4. Then assemble the drawers separately and test their movement to make sure they slide easily without force. 5. Finally, fully tighten all screws and check the fit of the drawers within the bed. In my experience, adjusting the drawer runners during a second pass helps the drawers run much more smoothly. For tools, you will need a Phillips screwdriver, a cordless drill with a torque setting, and a small rubber mallet. Hope this helps with your planning.
