ᐅ What are your experiences with assembling the Ikea Brimnes furniture?
Created on: 13 Nov 2024 08:37
Iliasken
Iliasken
13 Nov 2024 08:37
Good morning everyone, I’m planning to assemble a new Brimnes bed from Ikea in the next few days and would like to gather your experiences and tips in advance. Specifically, I’m interested in how easy the model was to assemble for you, whether there were any challenges during the build, and how sturdy the bed is for everyday use. I’m especially looking for advice regarding tools, the assembly instructions, and any potential issues with the drawers, which are known to be a bit tricky. Are there any improvements or tricks you would recommend? I appreciate all feedback, whether positive or negative!
KAULIS
13 Nov 2024 10:02
I have some clear experiences regarding the Ikea Brimnes and its assembly, which I would like to summarize here in an organized way. - The assembly instructions are basically understandable, but I recommend unpacking and sorting all parts completely before starting. - For the screws and dowels, it is advisable to use a cordless drill with adjustable torque to avoid over-tightening. - The quality of the wooden parts is solid, but not everything fits perfectly, especially noticeable with the drawers. - The drawer systems require careful alignment; otherwise, they tend to stick or rub quickly. - After assembly, the bed is quite stable, although I used additional brackets to reinforce the corners on my model. Overall, the assembly is manageable, but you should allow enough time and calm to complete it.
Dilen
13 Nov 2024 13:19
Hello Iliasken, your question about assembling the IKEA Brimnes is very well asked, as there are indeed several details to consider. I’m happy to explain in detail:
First, the preparation: Although the instructions are mostly visual, you should carefully check all parts at each step. I recommend sorting the fittings such as dowels, screws, and metal brackets in small containers beforehand; this way, you won’t lose any parts and can quickly see what you’ll need for the next step. For tools, a good Phillips screwdriver will do, and I use a cordless drill only cautiously for larger screws since the drawer spring mechanism can be sensitive to too much pressure.
Regarding the actual assembly:
- Start with the frame, which includes the wooden panels and the slatted bed base holder; I tightened each screw firmly by hand and fine-tuned them again after completing the assembly.
- Pay special attention to the drawers, as their runners are often the most challenging part. I recommend beginning with installing the drawer slides and checking multiple times to ensure they are in the correct position.
- Drawer runners leave little room for error — if they aren’t installed precisely, the drawer may jam or not slide smoothly.
Another tip: Include the mattress or bedding during your assembly, as you often only see how stable and manageable everything is once it’s loaded with weight.
Finally, my question to you: How much experience do you have with furniture assembly, and what tools do you have available? That could help me provide even more specific advice.
Palenar
13 Nov 2024 15:44
Dilen schrieb:
The drawer slides leave little room for error; if they are not installed precisely, the drawer will either jam or run unevenly.
I can only agree with that. I had a similar experience with my Brimnes bed: the biggest challenges arise during drawer assembly. It is important to have a level surface during construction to avoid any tilt that makes alignment difficult. I also recommend not fully tightening the screws until all parts are in place—adjustments are often necessary later. Another point I noticed is that the drill holes are not always perfectly finished, which sometimes requires light filing or correcting with an awl. Screwing too quickly here can damage the wood. Overall, I would say the bed is very functional and suitable for people without woodworking experience, as long as they take their time. I also find it practical that the drawers have smooth-rolling wheels that operate very smoothly when installed correctly.
juMira46
13 Nov 2024 18:20
Hey Iliasken, I have assembled the Brimnes bed twice now and can say: patience is key! 😅 The drawers can be tricky, but if you take it step by step (and maybe take a short coffee break in between), it works out well. My advice: take your time when aligning everything, because if the drawers get stuck, it can be very frustrating. The Ikea instructions are actually good, but sometimes it’s easier to follow the sequence exactly rather than trying to improvise. And a fun fact: the first time I built it, I had one screw left over, which I actually used correctly during the second assembly – so even pros make mistakes. 😉 Good luck!
blapau
14 Nov 2024 09:12
For stability and durability: The Brimnes bed serves well as a solid sleeping option, provided it is assembled correctly. A common mistake is uneven tightening of the screws, which reduces stability and can cause creaking over time. Also, the drawers should not be adjusted too tightly; they need some clearance to prevent faster wear of the runners. Personally, I recommend using standard wood glue on the wooden dowels to add extra strength to the structure. This is not an official Ikea tip, but a proven trick from my experience. Those who invest the necessary time and care will be rewarded with a sturdy and functional bed.
