ᐅ What exactly does the PLATSA assembly system at Ikea mean?
Created on: 3 Nov 2023 18:07
jorgetu
jorgetu
3 Nov 2023 18:07
Hello everyone, I am currently looking into the PLATSA assembly system from Ikea and would like to better understand what this system actually entails, especially compared to other Ikea systems like Pax or BESTÅ.
I am particularly interested in how flexible the system is, to what extent the components can be combined, and what specific features the assembly with PLATSA involves.
Are there any special assembly steps to watch out for? What about stability and possible expansions? I have read that PLATSA is very modular, but how is this really implemented in practice?
If anyone has experience with building or expanding it, I would appreciate detailed information or tips on what to consider and what the PLATSA assembly system from Ikea really means in practice.
nonpra
3 Nov 2023 18:23
PLATSA is characterized primarily by modular frames and flexible internal dimensions.
The frames can be customized individually and combined side by side or stacked. Assembly is straightforward because all parts are connected using standardized fittings. The system is relatively stable when the connectors are used correctly.
kaubi
3 Nov 2023 19:45
I would like to go into a bit more detail because, although PLATSA seems simple at first glance, it contains some special features during assembly.
The system is primarily based on a grid size of 40x40 cm (16x16 inches), which defines the basic structure of the modules. This grid allows for a wide variety of combinations with drawers, doors, or open elements. It is important to note that the individual frames consist of rectangular structures assembled with special connectors and concealed screws.
A key point is that assembly involves more than just screwing the parts together; precise alignment of the frames is essential so that doors and drawers fit properly and do not stick or sit too loosely. The instructions specifically explain what to pay attention to when screwing the frames to ensure they are set at right angles. Inaccuracies can otherwise cause problems with closing the fronts.
Stability is achieved through additional connecting rails and by attaching the units to the wall. Since many modules can be combined in very different ways, the system can theoretically withstand significant loads, provided the wall mounting is done correctly.
By the way, I am curious whether you have planned the system for a specific room size or a particular interior concept? Some details in the advice could address that more specifically.
jorgetu
4 Nov 2023 08:12
kaubi schrieb:
The system is mainly based on a grid dimension of 40x40 cm (16x16 inches), which defines the basic structure of the modules.
I find the grid dimension very interesting. I am planning to use the system in a small living room as a media wall. So not just cabinets, but also open compartments for devices.
How flexible are the shelves? Can their height be adjusted? And what about cable management options if, for example, you want to place a TV or amplifier inside?
I would also like to know if the system is easy to expand later in case I want to add something without having to change the entire structure.
JONSON
4 Nov 2023 09:47
The individual shelves in the PLATSA system are indeed adjustable in height, but only at predefined increments. This allows flexibility in positioning.
For electronic devices, there are dedicated cable management openings that can be integrated into the side panels. This is convenient if you want to organize media equipment.
Regarding expandability: PLATSA is designed to be very modular—you can easily add additional units later or modify existing ones. It is always important to ensure stability by anchoring the system to the wall, especially with taller assemblies.
ju_ren
5 Nov 2023 12:16
Briefly to add:
- Shelves have holes arranged in a grid pattern, so they can be moved flexibly.
- Cable ducts are separate inserts that can be easily attached.
- Extensions are compatible as long as they maintain the same grid spacing.
Be sure to plan for wall mounting.
