ᐅ What effort is required to retrofit IKEA BRIMNES drawers?
Created on: 16 Apr 2023 08:37
ALVAGO
ALVAGO
16 Apr 2023 08:37
Hello everyone, I am currently looking into adding extra drawers to my existing IKEA Brimnes dressers. I would like to understand what kind of effort can realistically be expected, especially regarding the required tools, the time needed, and the necessary DIY skills. Are there specific challenges to watch out for, for example when adjusting shelves or reinstalling the drawer slides? I am also interested in whether the upgrade is easier on certain BRIMNES models compared to others. Maybe someone here has practical experience and can give me an overview of how involved the process actually is and the best way to approach it.
Cecilera66
16 Apr 2023 09:14
The effort required to retrofit drawers in IKEA BRIMNES is manageable. Tools needed: screwdriver and possibly a cordless drill. Time varies depending on experience, approximately 30-60 minutes per drawer. It is important to have clear instructions and the correct original parts. Adjustments to shelves are usually not necessary.
Surela
16 Apr 2023 11:29
Thank you for the question, very well formulated and precise. To thoroughly address the topic of retrofitting drawers in IKEA BRIMNES units, I recommend the following explanation: In general, the effort is moderate if you have the correct original components. The main steps are:
- Disassembling the current setup or removing the shelves at the designated location
- Installing the side drawer slides (often, mounting points need to be drilled if the cabinet has no pre-drilled holes)
- Inserting and securing the drawer
Ideally, you will need a cordless drill with fine bits, a tape measure, and possibly a pencil for marking. It is essential to ensure that the furniture’s load-bearing capacity is not compromised — drilling too large or incorrect holes can reduce stability. With older or different BRIMNES models, there may be variations in hole placement, so comparing with the original setup is advisable.
Timewise, expect about 45 minutes up to a maximum of 90 minutes per drawer, depending on your DIY skills. If inexperienced, it is better to allow more time and possibly have a second person assist.
In summary: The retrofit is quite doable but requires care, especially when attaching the drawer slides, so that the drawer later operates smoothly and quietly.
Has anyone noticed whether there have been changes in the construction of the latest BRIMNES series that would significantly affect the effort required?
ALVAGO
16 Apr 2023 12:10
Surela schrieb:
For older or different BRIMNES models, there may be variations in the hole positioning, so comparing with the original assembly is advisable.
That’s an important point, thank you. Does anyone know if current BRIMNES dressers already have preparations for additional drawers, such as pre-drilled holes or similar markings? That would significantly reduce the effort. I’m also interested in how to ensure that the drawer runs smoothly later on, meaning it is level and closes properly. Are there common pitfalls to watch out for? Thanks in advance for your insights.
teyosef
17 Apr 2023 07:45
Here is a brief guide with some tips to make retrofitting drawers on BRIMNES furniture easier:
1. Preparation
- Check if your model has pre-drilled holes; newer versions often have mounting holes on the inside panels.
- If the furniture piece does not have these, you will need to mark and drill carefully yourself.
2. Tools
- Cordless drill with a Phillips screwdriver bit
- Tape measure, pencil
- Spirit level to align the drawers
3. Step-by-step
- Remove shelves or other obstacles
- Install the drawer slides following the IKEA instructions or those of compatible products
- Pay attention to correct height and alignment
- Insert the drawer and check that it slides smoothly
Common mistakes:
- Drill holes too far forward or backward → drawer hangs unevenly
- Drawer slides not mounted straight
- Applying too much force when screwing, which can damage the material
Tips:
- Work slowly and precisely
- Use a second person to help with alignment
- Double-check all measurements
Conclusion: The effort is moderate, about 1 to 1.5 hours per drawer, less if done carefully. The main challenge is positioning the slides correctly.
