ᐅ What does it mean: Floor area ratio 0.4, plot ratio 1.2, number of storeys II - II?
Created on: 26 Jan 2016 14:32
juus1
I found a development plan while searching for a plot, but I cannot interpret it.
The following is specified for the plot:
Site coverage ratio 0.4
Floor area ratio 1.2
Number of floors II - III
1) What does this mean?
2) Would the Viebrockhaus Maxime 300 be considered a two-story house or just one story?
Thank you very much and best regards,
Yavuz
link removed by moderation; please follow the forum rules.
Thank you!
Building Expert
Yavuz
Thank you!
Building Expert
[qoute]
Stories II - III
[/Quote]
This could also mean that you MUST build 2 full stories. The large floor area ratio allows for a huge house with 500sqm (5382 sq ft) of living space, which could be spread over 3.5 floors (3 full stories plus 1 attic floor).
There is still a lot to learn during construction, and many surprises. Even if things generally go well, you will be relieved when everything is finally completed.
The biggest problem is that there is no legal expenses insurance to enforce your rights if necessary. You have to deal with every issue yourself. It is all the more important to only pay invoices after the work has been completed properly and without defects.
We are still annoyed 3 months after moving in with minor issues such as a crooked sink, which the plumber refuses to replace or fix, a few scratches on the expensive extra-cost door, and other small construction quirks.
Stories II - III
[/Quote]
Bauexperte26 Jan 2016 21:27Payday schrieb:
Stories II - III
This could also mean that you MUST build 2 full stories. No. Only if the Roman numerals are circled. Regards, Bauexperte
Bauexperte
to make things a bit more complicated, I would like to add a few small but potentially important remarks.
@Payday: Whether terraces and driveways are included depends on the date when the municipality made the zoning plan publicly available. The zoning regulations valid at that time must be applied. The most significant changes, such as the inclusion of garages and ancillary buildings, occurred in 1990. However, the changes from 1968 should not be overlooked either. The city of Frankfurt am Main provides a very useful guide on this topic on its website.
@Bauexperte: If the way the number of floors is written in the zoning plan is really as stated, the information should be understood as minimum and maximum values, meaning at least two and at most three full floors.
@juus1: Your calculation of the garden depth assumes that you are allowed to build directly on the street boundary line. It might be worth checking whether building limits or setback lines are also established. If you already have fairly concrete ideas for your construction project, consider consulting with the building services.
Bauexperte27 Jan 2016 11:13Hello,
Best regards, Bauexperte
Escroda schrieb:That is also how I learned it; without a circle, the II- or III-storey designation does not necessarily have to be strictly followed. If the specification is found, as described and without a circle in the development plan, two storeys can be achieved according to calculations but still appear externally as a single storey.
@Bauexperte: If the notation of the number of storeys in the development plan is exactly as stated, the figures should be understood as minimum and maximum limits, meaning at least two, at most three full storeys.
Bauexperte27 Jan 2016 19:11How do you come to the conclusion that a bungalow might be permitted?
Regards, Bauexperte
Bauexperte
Regards, Bauexperte
Bauexperte
