ᐅ What are your thoughts on using adhesive tape when assembling Ikea PLATSA?
Created on: 23 Nov 2022 18:43
Laruka
Laruka
23 Nov 2022 18:43
Hello everyone, I am currently assembling an Ikea Platsa system, and I noticed that some people mention using adhesive tape as a helpful tool to hold parts in place or make the assembly easier. I’m interested in your opinions: What do you think about using adhesive tape when building Ikea PLATSA? Specifically, I would like to know if the tape actually offers any advantages, if there might be risks such as damage to the materials, or if it could have negative effects on stability and durability. Do you use it yourselves, or have you been advised against it? I appreciate any practical tips, personal experiences, or technical insights you can share!
Charles
23 Nov 2022 19:02
I find the question very well formulated and believe that the use of adhesive tape during the assembly of Ikea PLATSA should be considered with some nuance. As already mentioned, it can certainly help to temporarily secure smaller modules or individual parts, especially when working alone and stable clamping of boards is difficult. However, caution is advised, because PLATSA furniture is designed to be held together securely using connection elements such as dowels, screws, and clip mechanisms. Adhesive tape can damage the surface over time or leave adhesive residues, particularly on laminated surfaces. There is also a risk that the tape may slip under load, which complicates the assembly rather than supporting it. My advice: Use adhesive tape only temporarily and remove it completely once the actual connections are in place.
Davidleo
23 Nov 2022 19:21
Great topic, Laruka! 🙂 I used tape during the assembly of my PLATSA and found it really helpful! Fixing the back panels was particularly tricky, and the tape holds the parts perfectly in place until you screw them in. Of course, you need to be careful not to leave any adhesive residue on the smooth, finished surfaces. But I used a good painter’s tape, which comes off easily without any problems. My tip: don’t leave the tape on longer than necessary—only keep it on until everything is securely screwed together. And don’t worry, personally I don’t see any downsides; on the contrary, it makes the work easier and saves hassle! Keep the questions coming!
Gofoman
23 Nov 2022 20:10
Interesting, the discussion about repair aids and temporary fixation always makes me question the actual design. Why is tape often needed during the assembly of PLATSA? Doesn’t that suggest the design is not fully developed? If tape is even recommended, it forces the user into a sort of makeshift solution that the manufacturer apparently did not consider. In my opinion, using adhesive tape during assembly is more a sign of weakness in the construction or design—not the best solution but a workaround for shortcomings. As long as the product holds together firmly using the intended components, tape should generally be avoided.
faso31
24 Nov 2022 08:34
Gofoman schrieb:
In my opinion, adhesive tape during assembly is more of a sign of weakness in the construction or design
That’s a good point, but I would like to offer a slight dissent: Even if the design is fundamentally well thought out, in practice there are often many scenarios where small aids like adhesive tape can provide significant added value. For example, when working alone or when parts need to be held at awkward angles before a screw or anchor is installed. However, I agree that it is important to critically consider whether the benefit outweighs possible surface damage or residue left by the adhesive. From a technical perspective, it would make sense if manufacturers provided better temporary fixing solutions in the future instead of relying on such DIY methods.
Surela
24 Nov 2022 09:15
I would like to clarify some technical aspects, as adhesive tape comes in many variations and can have different effects depending on quality, adhesive type, and application:
- If you are just temporarily securing parts, vinyl or painter’s tape is usually ideal because it can be removed without leaving residue.
- Inexpensive PVC tapes, on the other hand, often leave sticky residues that can damage the surface of PLATSA or be difficult to remove.
- It is also important that PLATSA elements do not require a permanent adhesive surface but should be connected firmly through mechanical means.
- If tape remains applied for too long or is subjected to heavy stress, it can peel off paint layers or cause surface tensions when removed.
My suggestion would be to carefully consider at which stage of the assembly the tape is used: It is acceptable for temporary fixing during installation, but it must be removed gently and thoroughly before final connections are made. It is also only suitable if the adhesive joint is not subjected to significant load. I would also like to know if Laruka means specific areas on the PLATSA where tape is intended to be used?
