ᐅ What DIY tip can you give to someone experiencing problems with plaster?
Created on: 10 Dec 2020 18:23
Gukla39
Gukla39
10 Dec 2020 18:23
Hello everyone, I have a special request at the moment: I’m looking for DIY gift ideas for people who have issues with Malm furniture. Specifically, typical problems like squeaky or loose drawers, wobbly handles, or minor wood damage—things that can be fairly easily fixed by yourself.
I want to give something handmade that is not only practical but also helps those affected to easily and independently solve the most common Malm problems. Do you have any suggestions or personal experiences on how to approach these issues with simple DIY solutions and present them as a gift? Maybe small repair kits, instructions, or useful tools? I would appreciate concrete ideas and tips that are easy to carry out and ideally focus on the most frequent weak points of the Malm models.
Le-so
10 Dec 2020 19:06
A repair kit with Spax screws, wood glue, and felt pads often helps fix wobbly drawers and squeaky parts. A simple paper instruction is usually enough. Spray silicone lubricant is also a good option to stop squeaking.
glamo
10 Dec 2020 20:48
I find it interesting that you are focusing on DIY gifts that address specific problems with Malm furniture. To be effective, the gift should ideally cover the most common mechanical issues.
A complete set could, for example, include a small bottle of wood glue – perfect for loose slats or minor wood splits. Adding suitable wood screws (specifically designed for particleboard furniture) allows you to effectively tackle wobbly drawers.
It is also worth mentioning the often overlooked need to tighten or replace drawer runners, which can squeak or stick due to wear. For this, a dry candle or firm wax can be recommended; simply rub it on the runners to reduce friction problems.
Additionally, you could include a small laminated handout that explains step-by-step how to diagnose these typical issues and fix them with simple tools. A few side questions: How technical should the target audience be? Are they people who already have tools and basic skills, or should the set be as fully equipped as possible?
elgla
11 Dec 2020 08:15
I really like the idea of giving DIY gifts to help people take better care of their furniture. Malm furniture, in particular, often suffers from minor damage, and many people feel overwhelmed by it.
I recently had a problem with a squeaky drawer myself, and it was really helpful when someone gave me a small repair kit with oil, a screwdriver, and wood filler. It also gives a sense of support, knowing that you don’t have to throw the furniture away or buy new pieces immediately.
I would also suggest including small motivational messages or words of encouragement with such gifts, as some people are hesitant to make repairs. Including instructions for important steps to refer back to is also very valuable. Gifts like this don’t just provide tools; they build confidence in one’s own abilities. 🙂
Fitigu
11 Dec 2020 10:29
For a targeted DIY solution to common Malm issues, I recommend the following set:
1. A high-quality screwdriver with standard bits suitable for Malm screws.
2. Waterproof wood glue, especially designed for particleboard and MDF products.
3. Small felt pads to relieve moving parts and reduce squeaking.
4. A small lubricant (e.g., silicone spray) for maintaining metal tracks.
Additionally, clear and precise instructions should be included, addressing the most frequent problems step by step: handle attachment, tightening of back panels, repairing cracks or chipped corners.
This setup is practical, avoids unnecessary extras, and ensures that the recipient can start right away.
KUDAISY
11 Dec 2020 12:43
Here is a suggestion on how to put together the gift as a small tutorial package:
1. A sturdy screwdriver with both Phillips and flat-head bits – Malm often uses Phillips screws.
2. A small bottle of wood glue suitable for veneer and particleboard.
3. Felt pads in various sizes to protect drawer bottoms or furniture legs and to prevent squeaking noises.
4. A small lubrication set: silicone spray or PTFE spray for tracks and metal hinges.
5. A short printed guide (in A5 or A6 size) showing step-by-step how to tighten drawers or repair sanding marks with simple methods.
Common issues with Malm furniture often include screws left too loose or missing manuals. The instructions should address this, for example with tips on screw lengths – not every screw can be replaced easily, as some parts may crack if screws are too long.
If you like, I can prepare such a step-by-step guide for you to print and include.
