ᐅ What should I do if the doors of my IKEA Besta units no longer close properly?
Created on: 13 Aug 2020 08:23
chenglaHello everyone, I have a problem with my IKEA Besta cabinets. The doors no longer close properly, which shows as uneven gaps and sometimes sticking. I have already checked if the hinges are loose, but they seem to be firmly mounted. I’m wondering what could cause this and how to best fix the door issues? Are there common causes like warped doors, incorrect hinge settings, or maybe material fatigue in the Besta system? I would appreciate specific suggestions for diagnosing and practically adjusting the problem, preferably including recommendations for necessary tools and required steps. Thank you in advance!
For better understanding: Besta doors are usually equipped with adjustable metal hinges that have three adjustment screws.
- The horizontal alignment of the door can be finely tuned by turning the screw on the hinge mount.
- Vertical adjustment is made using the rear screw, which runs over the hinge cup.
- Depth and closing pressure are adjustable via the front screw.
A precise adjustment is the first and most important step.
If the problem persists despite correct adjustment, the door panel may be warped, especially due to moisture exposure. In this case, replacing the door or sanding the contact points is necessary.
Don’t forget: Connected furniture parts can easily shift due to load or installation errors, which can make closing difficult. Checking the entire cabinet and shelving construction is also recommended.
Hello chengla,
I understand that doors that do not close properly can be very frustrating, especially if you want to avoid visible gaps or pinch points. I’m happy to provide a more detailed explanation.
First, you should patiently go through the three adjustment options on the hinges: horizontal, vertical, and depth. Many people tend to adjust only one screw. It’s worth adjusting all three screws gradually and checking the result along the way.
It is also important to check the furniture itself. Sometimes loose shelves or a warped cabinet can affect the fit. Especially with older furniture or if it has been exposed to moisture, the wood panels can warp slightly.
If you suspect a warped door panel, it is definitely advisable to only make small corrections to the door, such as gently sanding the edges, and to avoid forcing it.
Helpful tools include:
- Phillips screwdriver (preferably with a slim head)
- Spirit level (to check furniture alignment)
- Optional small wedges or washers for support
If you like, I can also write you a step-by-step guide.
ladali schrieb:
- The door can be finely adjusted horizontally by turning the screw on the hinge mounting.
- Vertical adjustment is done via the rear screw that runs over the hinge cup.
- Depth and clamping pressure are adjustable with the front screw.
