Hello everyone, I have a Billy bookshelf with some missing or broken screws. Since I want to continue using the shelf safely and securely, I am looking for specific solutions on how to find replacements for these particular screws. I understand that it can sometimes be difficult to get the exact parts from IKEA, and I have also considered using similar screws from a hardware store. However, I am unsure about the correct size and strength, as the shelf has a load-bearing function. How do you deal with missing or damaged screws in Billy bookshelves? Do you have any tips on what to watch out for and where is the best place to get replacements? Thanks in advance for any helpful advice!
Hey Prafo! First of all, respect for not wanting to throw away the shelf right away 😄 For Billy screws, I usually go for original replacements from IKEA—they are often easy to order by just calling customer service, as they usually have the right screws. If that doesn’t work, I check at a hardware store for screws with the same diameter and length. The important thing is that the threads fit into the middle of the shelf board and that the material is strong enough (preferably galvanized steel). And a little tip: some Billy models use self-tapping screws, so not every regular screw will fit easily. If screws are damaged, a repair kit with dowels and matching screws often helps to secure everything properly again. Good luck, and get in touch if you need more details! 🙂
Hello Prafo, to help you effectively, it would be useful to know exactly which screws are missing or damaged – for example, the dowel screws holding the back panel in place, or the shelf supports? In general, I recommend using the original parts for Billy shelves because the wood panels and drill holes are precisely matched. Replacement parts are sometimes available directly through IKEA’s customer service. If that’s not possible, you can measure the screw diameter, length, and thread type using a caliper. Pay special attention to the thread type (M4, M5, etc.) and the length, as screws that are too long can damage the shelf, while screws that are too short won’t provide enough support. The correct screws should be made of stainless steel or at least galvanized steel to prevent corrosion. If the original drill holes are damaged, you can reinforce them using wood glue and smaller wooden plugs. If you like, I can also explain step-by-step how to do this properly. What exactly is broken or missing?
I can understand how frustrating it can be to be missing screws—especially when you use the shelf frequently and rely on its stability. Sometimes it feels almost helpless because not every screw from a hardware store is a suitable replacement. Have you tried contacting IKEA directly? Their staff are often very helpful and will send replacement parts, especially when it concerns series-specific components. If that doesn’t work, it would be useful to know whether the missing screws are in load-bearing areas or on the sides that experience less stress. This would help determine whether a DIY replacement is sufficient or if an original part should be used.
meGreg schrieb:
For Billy screws, I usually use original replacement parts from IKEA, which are often easy to order – just call customer service, they usually have the right screws.That’s exactly the approach I usually take as well, but unfortunately, some screws for the shelves on my Billy are broken and are no longer listed separately as replacements at IKEA. That’s why I’m considering whether an alternative from a hardware store might be possible. Can someone explain if you really need to stick to specific screw types, or if a slightly different screw could work for the shelves?
Elias schrieb:
Sometimes you almost feel helpless because not every screw from the hardware store is a good replacement.That pretty much describes my situation. I’m unsure if the screw will hold the shelf as securely as the original. Could there be a safety risk if the wrong screw is used?
