ᐅ What should I do if replacement parts for IKEA Besta are no longer available?
Created on: 3 May 2016 18:07
puvirginia
puvirginia
3 May 2016 18:07
I have a problem that might be familiar to some of you: I own an IKEA Besta wall unit, which I purchased a few years ago. Now, some spare parts, such as hinges and internal fittings, are unfortunately no longer directly available, neither in the IKEA online store nor at the nearest store. My question is therefore very specific and focused: What is the best approach when spare parts for the Besta series are completely unavailable?
I want to avoid buying the entire furniture set again, but without the right replacement parts, its functionality is limited. Does anyone have experience with good alternatives – whether through custom manufacturing, repair options offered by third parties, or perhaps suggestions for compatible spare parts from other series?
I would be very grateful for any practical and technically sound advice, as I would like to continue using this piece of furniture and don’t want to give up on it.
dota57
3 May 2016 19:43
puvirginia schrieb:
What is the best approach if spare parts for the Besta series are no longer available at all?
This is a common challenge with furniture whose production has been discontinued or where the availability of spare parts has gradually decreased. In your case, I would first recommend contacting IKEA directly again – often, some spare parts are not listed online but can still be ordered through stores or the customer service center.
If that doesn’t work, here are some alternatives:
- Third-party platforms or specialized furniture spare parts shops that offer compatible parts or can manufacture them.
- Local carpenters can often create a similar part based on measurements or a damaged sample.
- Attempting repairs yourself using suitable fittings from a hardware store or universal furniture fittings, where accurate measurements are important.
Having the exact spare part number and as much detailed information as possible helps a lot. Also, considering whether the function must be fully maintained or if a cosmetic repair is sufficient will influence your options.
In any case, I recommend patience and thorough research, as IKEA furniture spare parts are often more manageable than expected, even though some models are now less well supported.
fidasi
4 May 2016 09:22
puvirginia schrieb:
What is the best approach when replacement parts for the Besta series are completely unavailable?
To address the topic in more detail: shortages of replacement parts for IKEA Besta are quite common, especially for older models, since IKEA often stops stocking many parts after a certain period. Based on my experience with similar cases, there are several possible solutions that vary depending on the type of part needed.
First: the most common and essential replacement parts, such as hinges or shelves, can often be found from third-party suppliers specializing in IKEA-compatible furniture parts. These sometimes offer similar quality and, due to identical dimensions, can be used interchangeably, although the appearance may differ slightly.
Second: for parts with a specific function (e.g., drawer slides or special mounting brackets), it is always advisable to document the exact type and measurements—either by measuring or taking photos (though it may take time, measurements are essential).
Third: custom-made parts from carpenters or specialized workshops are an option, especially for wooden or MDF panels. This usually depends on the individual effort and cost involved—an economical alternative if the furniture piece is not too large.
Fourth: repairs using universal fittings and parts can work if you have some DIY skills. The limitations here mainly concern stability and precise fit.
I would like to know which parts are missing or damaged exactly, so I can provide more specific advice. Sometimes with just a few measurements and some details, a more precise recommendation can be made. For example, are you having problems with a particular hinge or drawer mechanism? This makes a significant difference.
RON57
5 May 2016 07:56
puvirginia schrieb:
I want to avoid buying the whole furniture set again, but without the right spare parts, the function is limited.
Anyone who has ever tried to repair an older piece of furniture will be familiar with this issue, especially with IKEA furniture, which is often modular but has limited spare part availability over the years.
Here are a few practical steps I recommend:
- Search local classifieds or online auction sites for used pieces from the same Bestå series or model line. This is a good way to find matching spare parts, as many people dismantle furniture or sell individual parts.
- Check regional furniture exchange platforms or swap groups – it often helps to provide exact measurements and a photo of the part you need.
- If you have DIY experience, it can be useful to use a damaged part as a template and either reproduce it yourself or ask a carpenter to make one.
- It might also be worth contacting IKEA customer service by phone or email. Sometimes they still have leftover stock that is not publicly listed.
In many cases, a bit of patience and research is enough to find good solutions without having to buy new furniture.
