ᐅ What should I do if the screws for the Ikea PLATSA system are too short?
Created on: 20 Nov 2022 14:23
Klosu37
Klosu37
20 Nov 2022 14:23
I recently assembled an Ikea Platsa shelving unit and noticed that the supplied screws are clearly too short to securely connect the intended parts. Specifically, these are the screws for the side panels, which are supposed to ensure stability. I have checked various types of screws and even used some replacement screws, but either they are too short or the thread type does not match.
My question is: What should I do if the Ikea PLATSA screws are too short?
Does anyone have a proven method for handling this situation without compromising stability or damaging the furniture? I would appreciate concrete advice, such as suitable replacement screws, tool recommendations, or tips for extending or reinforcing the connection. Thanks!
cassandra
20 Nov 2022 15:12
Klosu37 schrieb:
What should I do if the screws for Ikea PLATSA are too short?
If the screws for Ikea PLATSA are too short, I recommend the following approach:
- Check if there are other screws included in the package that are longer, and use those if available
- Look for replacement screws with the same thread size but longer length (e.g., M4x50 instead of M4x30) at hardware stores
- Make sure the screws are not too long to avoid damaging the material
- Alternatively, use wall plugs or screw anchors if the material allows it
The stability must not be compromised, so do not use screws that are too long or too short for the material. Ideally, compare the original screw briefly at a hardware store.
Tools: ratchet or cordless drill with torque control to prevent over-tightening.
This approach ensures the furniture is properly secured.
naujon
20 Nov 2022 16:07
cassandra schrieb:
Look for replacement screws with the same thread but longer length (e.g., M4x50 instead of M4x30) at hardware stores
Additionally, I would like to provide a step-by-step guide on how to proceed when Ikea PLATSA screws are too short:
1. Identify the screw type – usually metric threads, most commonly M4 or M5.
2. Measure the screw length precisely; the length including the head is important.
3. Purchase screws at a hardware store with the same thread type but about 10-15 mm (0.4–0.6 inches) longer.
4. When replacing, be careful that the screw is not too long to avoid puncturing or damaging the material.
5. Use washers if the fit is too loose.
Common mistakes: Using screws with the wrong thread or too large a diameter. This can damage the threads in the furniture components.
Conclusion: Accurate measuring and some caution ensure a safe and stable solution.
warrenka57
21 Nov 2022 09:39
I once had a similar problem with PLATSA screws – they were unfortunately too short, and I wasn’t sure if I could just buy longer screws.
naujon schrieb:
Typical mistakes: Using screws with the wrong thread or too large a diameter. This can damage the threads on the furniture parts.
I definitely wanted to avoid that, so I approached the situation very carefully. In the end, I actually found suitable screws at the hardware store (same brand, just 10mm (0.4 inches) longer), which fit perfectly.
For me, it was important to check the connections afterwards to make sure they were tight – I used a small tool set with a torque wrench to avoid over-tightening.
What also helped was reading through various forums. Sometimes others have similar issues with Ikea, and exchanging experiences with like-minded people can be very reassuring.
pikin
21 Nov 2022 12:15
Klosu37 schrieb:
What should I do if Ikea PLATSA screws are too short?
A precise approach is important.
I recommend:
- Measuring the existing screw accurately
- Identifying the thread type
- Using alternative screws with the same thread type and appropriate length
- Being careful with screws that are too long, as they might penetrate the material
Also, keep in mind that Ikea furniture often consists of wood fiberboard (chipboard). Therefore, screws with a fine thread are preferable to avoid damaging the material.
For extra safety, you can slightly adjust the screw’s thread with a file if the thread differs slightly from the original.
This issue has often been resolved by using longer original screws or very similar replacement screws.
tyson51
22 Nov 2022 08:03
Briefly, my experience: Sometimes it’s not just the length but also the quality of the screws from Ikea that isn’t ideal. I recommend using high-quality screws of the correct length, which can be found at any hardware store.
Important points:
- Know the exact size of the screw
- Preferably use stainless steel or galvanized screws for better durability
- When in doubt, choose a slightly longer size rather than one that’s too short
This way, you avoid problems with the safety and stability of the furniture.
