ᐅ What should I do if Ikea HEMNES drawers don’t slide properly?
Created on: 26 May 2020 08:37
Drati
Drati
26 May 2020 08:37
Hello everyone, I recently bought an Ikea Hemnes chest of drawers and installed the drawers during assembly. Unfortunately, they don’t slide in and out properly; they stick and get caught at certain points. The drawer runners are installed correctly, and the wood doesn’t seem warped. My question is: What can I do if Ikea Hemnes drawers don’t slide smoothly? Are there common issues or adjustment tips I might have missed? I would appreciate any help!
rimole
26 May 2020 09:12
First, check if the drawer slides are installed completely straight and parallel. Screws can come loose or be misaligned. Then remove the drawer, clean the slides, and apply a light lubricant.
ritotar
26 May 2020 10:01
The problem is unfortunately not that uncommon; the HEMNES sometimes seems to have a mind of its own 😅. Check the rails at the back or the drawer itself for any slight warping or chips that might be causing it to catch. Sometimes gently readjusting the drawer in the track helps—don’t tighten it too much!
Tommy38
26 May 2020 11:45
Hello, I am familiar with the issue of sticking drawers in the Ikea HEMNES series. It is often caused by a slight misalignment of the metal slides or slightly uneven installation. After installation, the slides should be mounted precisely parallel, and no screws should be loose. It helps to follow these steps:
- Remove the drawer
- Check the slides for correct and tight screw fastening
- Inspect the guide rails for dirt, wood splinters, or paint residues
- If the wood is rubbing against the slides, gently smooth the affected areas at the corners with fine sandpaper
- Slowly slide the drawer back and forth several times before loading it fully again
With patience and careful adjustments, the functionality usually improves significantly.
bauku
27 May 2020 07:25
Hey! This is often just a matter of fine-tuning! 🙂 I had the same issue recently with my HEMNES. Try laying the cabinet on its side and carefully check if the rails are perfectly aligned. Sometimes the wood surface can feel a bit rough due to the finish, and a little bit of sandpaper often works wonders. Just gently sand the edges of the drawer a little, and then everything will run smoothly! Good luck and don’t give up, you can do it!
REOHEINRIC
27 May 2020 08:58
Drati schrieb:
I am grateful for any help!
This malfunction with Ikea HEMNES drawers usually results from a combination of two factors: inaccuracies during the installation of the drawer slides and minimal dimensional variations in the wooden components. Recommendations:
- Use a square to check the alignment of the slides.
- Check whether the drawer is hitting the frame or the slides.
- If necessary, adjust the screws in small increments.
- Clean the slides and lubricate them with a suitable lubricant for metal-to-wood contacts.
- If problems persist, lightly sanding the edges of the drawer where contact occurs can be helpful.
These measures are based on practical experience from multiple installation cases and should be followed systematically.
