ᐅ What should I do if I need to stop assembling the IKEA Platsa system?
Created on: 23 Dec 2018 14:12
kenbekim35
I recently started assembling my IKEA Platsa wardrobe. Unfortunately, due to time constraints and the lack of suitable helpers, I am now considering stopping the assembly because I am unsure how to safely and securely store the furniture until I can continue at a later time without causing any damage.
Therefore, I am interested in knowing: What should I do if I have to pause the assembly of the IKEA Platsa? Is there a recommended way to safely store partially assembled parts? How can I prevent screws, panels, or connectors from getting damaged?
Also, should I completely disassemble all parts again, or is it okay to leave the current progress as it is, for example if the back panels are already attached?
I look forward to your experiences, tips, and advice!
CHENNE
24 Dec 2018 08:29
As a general recommendation, lay flat panels on a hard, level surface and avoid placing heavy objects on top of them. For assembled parts, such as carcasses with attached back panels, store them upright on a stable surface to prevent warping or tipping.
Regarding doors and drawers: if possible, it is advisable to remove them, as they add weight and can be damaged if stored improperly.
This can also make reassembly easier, since fewer assembled parts may cause issues during storage.
Clearly labeling all parts and organizing screws and fittings helps minimize confusion later on.
sifa65
24 Dec 2018 09:56
From my experience, the biggest risks when dismantling a structure are losing small parts and warping wooden components.
- Therefore, be sure to collect screws, dowels, nails, and fittings in small labeled containers or bags.
- Store large panels flat and dry, avoiding stacks that could cause warping.
- For assembled carcasses, the back panel should always remain in place, as it provides significant stability.
Doors and drawers should be removed to prevent them from being stressed or damaged.
Lucki
24 Dec 2018 10:31
Hey, taking short breaks makes it easier to manage! 🙂
Of course, if you need to pause the construction, make sure to secure all screws and fittings well, and leave the back panels in place – this provides great stability. You can remove doors and drawers to prevent them from getting damaged. This way, continuing the work will be much more relaxed!
MANUEL
24 Dec 2018 11:14
Sort screws and store large parts flat. Keep the back panels attached, remove doors and drawers. The rest then follows the instructions for continuing assembly.
Davidleo
24 Dec 2018 12:47
kenbekim35 schrieb:
Could you explain in more detail which parts definitely should be left attached and which absolutely must be completely disassembled?
Gladly! Here’s what I did:
- Left the cabinet body with the back panel fully assembled (for maximum stability!)
- Removed doors and drawers since they are delicate and can be easily damaged
- Strictly sorted and labeled screws and small parts
This helped me a lot later on to reassemble everything quickly and without damage. Again: photos of the intermediate stages are incredibly helpful!
