ᐅ What should I do if an IKEA BRIMNES drawer gets stuck?
Created on: 27 Jan 2022 08:47
KENGU
Hello everyone, I have a somewhat unusual question: My IKEA Brimnes dresser has a drawer that suddenly got stuck. It won’t open or close properly. I haven’t noticed any visible damage. Are there any known causes for such drawer jams with Brimnes drawers, and how can I best fix the problem myself without damaging the drawer or the furniture? I would appreciate concrete tips for troubleshooting and repair options, ideally step-by-step instructions or practical advice that has helped in similar cases.
GLAEL
28 Jan 2022 11:07
Do you often use the drawer with heavy loads? Sometimes the runners bend or the rollers become loose. Carefully remove the drawer and inspect the guide rails. Usually, cleaning and a light silicone spray help. Replacing the rollers may be necessary.
AUSTINREN
29 Jan 2022 08:22
To systematically fix a jammed Brimnes drawer, please consider the following steps:
- Carefully remove the drawer by releasing the locks on the runners.
- Inspect the side rails for any deformations, loose screws, or foreign objects.
- The alignment of the furniture piece is important – if the dresser is not level, this can cause jamming.
- Check the rollers for damage and ensure they rotate smoothly.
- Avoid using oil-based lubricants as they attract dirt.
- Use silicone spray on the sliding parts to ensure smooth and clean operation.
Replace any defective components. Following this systematic approach will ensure lasting functionality.
joroti
29 Jan 2022 09:55
Julien schrieb:
Most of the time, this is caused by the rail or the rollers running incorrectly due to excessive weight or improper loading.
This is often the case. I would also recommend checking the drawer not only for the sliding rails but also for worn or damaged plastic parts on the back. Sometimes the drawer sticks because the back panel is not properly fitted.
