ᐅ What DIY options are available to make Ikea Hemnes furniture water-resistant?
Created on: 24 Mar 2021 18:21
DUPLO1
DUPLO1
24 Mar 2021 18:21
I am currently planning to use some Ikea Hemnes furniture (mainly dressers and nightstands) in damp rooms or somewhat demanding environments. This raises the question of what DIY options are available to make these pieces waterproof or at least significantly more water-resistant.
I understand that Hemnes furniture is usually made of solid pine with a coating or a thin layer of lacquer. The surfaces are therefore not inherently very water-repellent. I am interested in practical yet gentle methods that I can apply myself (spray sealants, oils, waxes, special varnishes, etc.).
Which products or techniques have worked well for you? Do you know how long the protection lasts and if there are specific areas that should be treated more thoroughly?
Looking forward to your tips and experiences!
RETRAVIS
24 Mar 2021 19:03
Regarding how to make Ikea Hemnes furniture water-resistant, there are several practical approaches that have proven effective.
- First, the surface should be thoroughly cleaned and lightly sanded to ensure better adhesion of the new protective layer.
- For long-lasting sealing, I recommend using high-quality clear spray varnishes, ideally polyurethane-based coatings. These are water-resistant and durable.
- Alternatively, specialized wood oils, such as tung oil or Danish oil, can reduce moisture absorption, but offer less water resistance than varnish.
- Waxes can improve protection but usually provide only short-term effectiveness and require regular reapplication.
- Edges, joints, and surfaces that come into direct contact with water are particularly vulnerable. These areas should be treated carefully and with multiple layers.
Regarding durability: a professional varnish layer lasts several years, while oils and waxes typically last months, depending on usage.
Overall, polyurethane varnish is my preferred choice when long-term protection is needed.
V
Victor54
24 Mar 2021 21:07
RETRAVIS schrieb:
For a long-lasting seal, I recommend using high-quality clear coat sprays, ideally polyurethane coatings.
Caution is advised when simply spraying clear coat over Ikea Hemnes furniture without considering the material properties.
The Hemnes pieces are partly made with multilayer glue and already have clear coat layers that do not always react optimally to new paint. Without careful sanding, delamination or uneven surfaces may occur.
Furthermore, the thicker the clear coat layer becomes, the more the natural appearance can change. For some, this can be an issue.
Therefore, my recommendation is to perform a local test on a hidden spot or a sample piece before painting.
Also, I wonder if it might be more sensible to use special water-repellent stains that remain breathable and do not completely seal the wood. This way, the wood is less stressed, and the piece ages more naturally.
Arianeo
25 Mar 2021 08:45
I would like to take a closer look at the different methods to make Ikea Hemnes furniture either completely waterproof or at least water-resistant.
- Varnishes: There are special water-based polyurethane varnishes that are low odor and suitable for indoor use. It is important to apply several thin coats and allow them to dry thoroughly.
- Wood oils: Products like linseed oil or tung oil can impregnate the wood and increase water resistance, but they are not fully waterproof. Therefore, they are better suited for furniture that is not directly exposed to moisture.
- Hard wax: Wax provides a nice surface with light water repellency, but it needs to be reapplied every year.
- Epoxy resin: For a highly waterproof and durable surface, epoxy resin can be applied in a thin layer. However, this is more labor-intensive and significantly alters the appearance.
In general, I recommend cleaning the furniture thoroughly before treatment, lightly sanding it, and testing the chosen product on an inconspicuous spot or a scrap piece to see how it reacts with the Hemnes finish.
In conclusion: If the furniture will be exposed to significant moisture, you should also consider using solid wood furniture without particleboard or foil-coated options. Hemnes is solid wood but not specifically designed for wet areas.
Ixfu2
25 Mar 2021 10:17
Short and to the point:
- Sand
- Apply clear varnish (PU or acrylic) in several coats
- Pay special attention to edges and joints
- Alternatively: apply tung oil, which takes longer but is more natural
This is usually sufficient to better protect Hemnes furniture from water.
