I am planning to customize my IKEA Platsa furniture a bit more uniquely and am looking for good DIY ideas that go beyond the usual paint jobs. Specifically, I am interested in suggestions for functional modifications, smart organization systems, or visual customizations that can be implemented technically without completely compromising the modular features of the Platsa range.
Has anyone in this forum already completed projects with Platsa and can offer tips on materials or methods that are especially practical or durable? Maybe small adjustments for specific use cases like a home office, media furniture, or hallway storage?
I look forward to your experiences and suggestions!
The Platsa series offers a very flexible basic structure that can be easily expanded. For example, if you want to integrate a desk, it is important to check the floor load capacity: the thin particleboards are not infinitely durable, so I always recommend additional reinforcement with plywood panels.
For organizing systems, I often use plywood drawer organizers that can be cut to size. It is important to pay attention to the installation dimensions, as the Platsa drawers are slightly narrower than comparable models.
Visually, the surfaces can be enhanced very well with wood trim, veneers, or chalk paint. When painting, I advise applying several thin coats instead of one thick one to avoid cracking. Also, sanding beforehand is very important because the surfaces are heavily melamine-coated.
I’m curious: What is most important to you in the furniture? Functionality, appearance, or both?
bapar schrieb:
I’m curious: What matters most to you about the furniture? Functionality, appearance, or both?Thank you for the detailed response! For me, both aspects are equally important. Essentially, I want to create an everyday item that offers sufficient storage space for the office while also looking high-quality and modern. The main challenge is maintaining modularity so that everything can be taken apart or rearranged later if needed. Functional additions like built-in cable management channels or flexible interior compartments are highly desirable.
That sounds like an exciting project! For functional extensions, I often use simple cable ducts from hardware stores, which can be easily mounted on the back without damaging the furniture. This way, you can neatly hide the cable clutter.
Regarding flexible interior layouts, I recommend working with custom-made dividers using wooden slats or acrylic. The Platsa modules have a very straightforward design, so these inserts can be easily fixed to the side rails.
For the final visual touch, I have had good experience with matte spray paints, especially if you lightly sand the surface beforehand. Applying high-quality wallpaper or thin veneer strips is also a great way to achieve a natural wood look.
If you like, you can post the exact measurements of your current furniture, and I can provide you with more specific advice.
A factual addition: Those who want to ensure the stability of Platsa furniture while still customizing it should pay attention to the choice of materials. Instead of solid wood slats, aluminum or steel profiles are suitable as reinforcements, which have a minimal visual impact due to their small cross-section.
For built-in cable ducts, flat cable channels with removable covers are recommended, which can be installed under shelves or behind paneling. It is also important to ensure adequate ventilation for electronic devices if the cabinets are expanded with equipment.
When it comes to interior organization, modular inserts with adjustable compartments made of MDF or plastic are practical. These can be quickly removed or rearranged as needed. Another tip: magnetic catches instead of the original screw fasteners allow for residue-free disassembly.
