ᐅ What are some DIY ideas for IKEA HEMNES shelves?
Created on: 3 Oct 2023 14:37
Giix63
Giix63
3 Oct 2023 14:37
I’m thinking about how to customize the IKEA Hemnes shelves through DIY projects so they are not only functional but also visually distinctive. Specifically, I’m looking to gather creative yet practical ideas that are easy to implement without requiring too much prior craftsmanship skill or extensive materials. Does anyone know of interesting tutorials or have experience on how to improve the Hemnes shelves, for example by modifying the design, breaking up the classic shape, adding integrated lighting, or turning them into multifunctional furniture or storage solutions? I’m also interested in tips for color schemes, combining them with other furniture pieces, or clever uses beyond just a “shelf.” Looking forward to your suggestions and examples!
bauku
3 Oct 2023 15:09
Hey Giix63, great question! 😊 I’ve customized several HEMNES shelves and can share a few ideas that are really fun and not too complicated.
- Simple paint job: You can completely refresh the shelf with chalk paint or lacquer – popular choices are pastel shades or a vintage look achieved by deliberately stripping and lightly sanding.
- Add lighting: LED strips along the inner edges or small built-in lights make the shelf a real eye-catcher and improve usability in low-light conditions.
- Replace back panels: Instead of the original back panel, you can attach attractive fabrics, corkboards, or magnetic boards to increase functionality and personalize the look.
- Modify shelf doors: Installing sliding fronts or glass doors adds variety and protects from dust.
I also once transformed a HEMNES shelf into a small room divider with plant compartments – it looks great and brings fresh greenery into the space. You can do it! Give it a try and feel free to share your results 👍
Marlenepa
4 Oct 2023 09:28
Hello Giix63,
I would like to share some general tips that are often useful when working on DIY projects with HEMNES shelves.
First, check the material of your specific model, as working with solid wood requires different tools and preparations compared to MDF or particleboard. HEMNES is usually made of solid pine, which is easy to work with.
Regarding traditional finishes: Make sure to use water-based paints and sealants if the shelf will be wiped down frequently with moisture. There are also special waxes that don’t seal the surface but change the appearance.
If you want to add lighting, I recommend using USB- or battery-powered LED strips with motion sensors that can be installed discreetly. This way, you avoid complicated wiring.
A simple and very effective modification is replacing the back panel with magnetic paint or a chalkboard surface, where you can attach notes or write with chalk. This makes the shelf multifunctional.
Last but not least: For greater stability when carrying heavy loads or if modular combinations are desired, additional mounting screws and corner brackets can help prevent sagging.
I hope these tips are helpful to you.
CHENFAR
4 Oct 2023 17:03
bauku schrieb:
- Installing lighting: LED strips along the inner edges or small built-in lights can make the shelf a real eye-catcher and improve usability in low light conditions.
Lighting is indeed a very practical and achievable idea. It is important to plan cable routing discreetly with HEMNES shelves, as these typically have solid side panels. Cable ducts or running cables behind the back panel, which can be replaced with a thinner back panel if needed, are workable solutions. You should also consider the power source – nearby outlets or the use of USB power packs offer flexible options.
Marlenepa schrieb:
Regarding traditional color schemes: make sure to use water-based paints and sealants if the shelf will be frequently wiped down with moisture.
This is an important tip. Acrylic- or latex-based paints are often better suited than oil- or chalk-based paints when the furniture piece is heavily used.
Another idea I recommend is adding extra shelving through custom-made wooden inserts, such as small shelves or boxes that can be hung inside the unit. This way, you can increase space utilization without permanently altering the furniture. A clever alternative is also pull-out drawers that you can make yourself for small items that might otherwise get lost on shelves.
When done neatly and practically, this is a very sustainable solution.
sinhau
5 Oct 2023 12:47
I would like to share a brief guide on how to upgrade a HEMNES shelf unit with LED lighting and removable cabinet doors. This is a nice DIY project suitable for beginners to advanced users.
1. Gather materials:
- LED strips with power supply or USB connector
- Magnetic catches for doors
- Hinges in case you want to add or replace doors
- Screws and optionally wood varnish or paint
2. Preparation:
- Measure all dimensions of the shelf unit and plan where to place the LEDs. The upper inner edges usually work best.
- Decide whether the doors will just hang over or need to be fully attached.
3. Installation:
- Attach the LED strips using 3M adhesive tape at the planned locations. Route cables neatly in cable channels or behind the back panel.
- Install the new doors with hinges if desired. Magnetic catches ensure easy opening and closing.
4. Painting:
- Paint or stain as desired, possibly highlighting only certain parts with color.
5. Final steps:
- Check that everything functions properly. Ensure all attachments are secure.
Common mistakes include careless cable routing that damages the LEDs, and inaccurate measuring for doors, which results in poor closing mechanisms.
Important tip: Work slowly and always consider if there is a simpler alternative to the planned step. This way you can avoid frustration and rework.
Good luck!
