Hello everyone, I am planning to upgrade my IKEA Platsa cabinets with a DIY solution, specifically looking for practical and visually appealing handle alternatives. I find the standard handles often feel a bit impersonal and would like to add some individuality instead. My question to the group is: What DIY handle alternatives are there for IKEA Platsa that are easy to install, durable, and possibly cost-effective to make yourself? I am especially interested in mechanical solutions that don’t require complicated tools, as well as aesthetic options using different materials such as wood, metal, or leather. Are there any tips for attaching handles without pre-drilled holes or creative ideas for multi-cabinet setups? Looking forward to your experiences and recommendations.
Regarding the question about DIY handle alternatives for IKEA Platsa, I would like to highlight a few key points. In general, the attachment mechanism for IKEA flat-pack furniture is often designed for screws with pre-drilled holes. This means:
- Handle strips made of wood or metal can be relatively easily attached to the existing holes using standard screws.
- A very popular DIY alternative is leather loops: these are fixed to the front panel with small screws or even nails, offering a rustic yet modern look.
- It is important to carefully check the dimensions of the holes. For those who do not want to drill holes, hook-and-loop tape or magnetic solutions can be used, although these are less durable for frequently used fronts.
- For a sturdy alternative, handles can also be made from decorated wooden blocks or metal rings, which are also fixed with screws.
In summary, I recommend first deciding on the type of attachment and material, then having simple tools like a cordless screwdriver, screwdriver, and tape measure ready. This reduces complexity and ensures a clean result.
I totally understand why you’re looking for creative handle alternatives for your Platsa. I felt the same way because the standard handles didn’t match my interior style, and I wanted something that also expressed a bit of personality.
I can personally recommend this from experience. The leather straps are not only easy to install, but they also feel great and age beautifully. I fixed mine with small brass screws, which looks really high-quality.
I also tried versions with decorative cords that you thread through existing holes and knot on the inside. This is especially affordable, and you can customize the colors to your liking.
If you want something a bit more crafty, you could try simple wooden blocks or rounded wood pieces – sand them down and treat them with wood oil. Especially if you like natural materials, this is a nice option. The attachment is similarly easy, but the look becomes much more unique.
I hope this gives you some ideas! Thanks for the great topic, looking forward to more suggestions.
KLONA schrieb:
A very popular DIY alternative is leather straps: you attach them to the front with small screws or even nails, which creates a rustic, modern look.
Short and precise:
- Attach leather tabs with small screws
- Use wooden strips and screw into drilled holes
- Round metal rings as handles
- Strong double-sided tape (only for lightly loaded cabinets)
- Thread ropes/paracord through holes and knot inside
For most DIY options, you will need a cordless drill and screws of the appropriate size. No drilling necessary if you use existing holes.
