ᐅ What are the differences between older and newer IKEA PLATSA models?
Created on: 21 Jul 2021 08:23
meben9
meben9
21 Jul 2021 08:23
I am currently looking into the specific differences between the older and newer IKEA Platsa models. I am interested in both technical aspects, such as improved materials or assembly methods, and functional differences, for example in the adaptability of the modules, interior fittings, or the available colors and finishes. Perhaps there have also been changes in dimensions, stability, or the range of products offered? I look forward to detailed answers that ideally explain which version is better suited for which purpose and why IKEA has updated the model.
paulu
21 Jul 2021 09:54
The new PLATSA models often feature updated connectors, making assembly easier. In addition, there are expanded options for fronts and colors. Stability has generally been improved. Dimensions have remained largely the same.
kulau
21 Jul 2021 11:37
Your question is very well chosen, as the differences between older and newer PLATSA models are quite varied. First of all, IKEA has largely maintained the module dimensions and internal measurements in the redesign to ensure compatibility. However, the screws and connectors have been technically improved to allow for both a sturdier construction and easier assembly. In particular, there have been changes to the wall mounting systems, which have become more flexible to better accommodate different wall types. The new surface options stand out with a wider range of colors and improved coatings—matte, scratch-resistant materials have been introduced, which are likely more durable than the older versions. The interior fittings and accessories, such as those for drawers and compartments, have also been further developed, making it possible to create more functional internal layouts. I would be interested to know what purpose you plan to use your PLATSA for. Are you looking for a modular solution that can be adapted, or a fixed piece of furniture?
benfa
21 Jul 2021 13:15
I believe it is important to critically evaluate whether the new models actually represent an improvement or if they are mainly design adjustments intended to create the impression of progress. When I look at the changes, I primarily see trendy color updates and somewhat improved hardware, but no fundamentally different construction. The question is whether these optimizations genuinely enhance ease of installation and durability in a noticeable way—or if the focus is more on increasing sales. Can anyone share concrete experiences regarding the long-term quality of the new PLATSA generation? The theory sounds solid, but how does it hold up in practice?
angel
22 Jul 2021 07:48
I can gladly provide some additional insights based on several self-assembled units of both newer and older PLATSA models. A major advantage of the newer models is definitely the improved modularity: the combination of individual components has been made simpler and more flexible, which especially benefits living in small spaces. Additionally, as mentioned before, the new fronts are more resistant to scratches and fingerprints. During assembly, it’s also noticeable that IKEA has made the instructions clearer, reducing the chance of errors. The back panels in the new models are often more robust and thicker, which enhances overall stability. However, I still recommend paying close attention to properly securing the modules to the wall, as the stability of PLATSA units generally depends greatly on wall anchoring. The storage space per module has hardly changed, which is usually appropriately sized for small apartments.
paulu
22 Jul 2021 10:02
benfa schrieb:
The question is whether these optimizations actually improve ease of assembly and durability significantly
From my experience, yes. The new connection methods are more robust, and the instructions are clearer, which saves time and frustration during construction.
