ᐅ What types of damage are most common with IKEA Hemnes beds?
Created on: 20 Jul 2023 08:17
Sartu
Sartu
20 Jul 2023 08:17
Hello everyone, I have recently been looking more closely into the most common defects and damages that occur with IKEA Hemnes beds. Especially with furniture made of solid wood components and various joints, I got the impression that there are typical weak points that are not easy to fix. Therefore, I am specifically interested in which types of damage occur most frequently with IKEA Hemnes beds. It would be helpful to know whether these are mostly manufacturing issues, material fatigue, screw connections, or perhaps broken slatted bed bases. Anyone who has had a Hemnes bed for a longer time or works professionally with furniture repairs is welcome to share more detailed insights. I look forward to many findings and experiences!
LOGEMIN
20 Jul 2023 09:02
Hello Sartu,
This is a really important question because with wooden furniture like the IKEA Hemnes bed, there are some common issues you should be aware of. I’ll try to explain them in a more structured way:
- Screws loosening: Especially with frequent assembly and disassembly, screws and wooden dowels can wear out, leading to wobbly constructions.
- Notches and splintering on the bed frame: Since the parts are made from solid pine wood, small cracks or splinters are often visible, especially at corners and joints.
- Issues with the slatted frame support: Some users report that the support slats break or deform, which puts stress on the slatted base.
- Paint and surface scratches: These are common, but the Hemnes’ semi-matte finish is sensitive to moisture and scratches.
My advice: Pay special attention to clean and secure screwing during assembly, using wood glue on joints can help, and make sure the slatted frame supports are stable.
If you want details on any particular point, I’m happy to provide more information.
Keatondra
20 Jul 2023 09:46
LOGEMIN schrieb:
Screw connections loosen: Especially with frequent assembly and disassembly, screws and wooden dowels can wear out, leading to unstable constructions.
I can confirm this, especially since Hemnes beds are often used in different living situations, for example during moves. In addition to the screw connections, I have often read about warped side panels that make the bed unstable.
This often happens when the bed is placed in relatively humid environments. The wooden parts react to humidity. Pine wood is particularly sensitive to this.
Another common issue is damaged or broken slatted bed bases, which are not directly caused by the bed frame itself but certainly affect sleeping comfort. With the IKEA system, it can happen that cheap slatted bases are used, which are not always sturdy enough.
jan10
20 Jul 2023 10:03
After about 3 years, I noticed that one of the screws on the headboard of my Hemnes bed had become loose. This quickly caused wobbling. Tightening the screws usually solves the problem. I didn’t experience any other damage.
kautra
20 Jul 2023 10:29
Cracks at the slat support points and loosening of screw threads are normal for Hemnes. The wooden dowels tend to pull out if the bed is moved frequently. The only solution is regular inspection.
LOGEMIN
21 Jul 2023 07:51
jan10 schrieb:
I noticed that one of the screws in the headboard of my Hemnes bed became loose after about 3 years.
This is a good example. Screws can loosen not only due to wear but also when the assembly torque is not applied correctly.
I recommend not only tightening the screws but also, in case of minor damage, partially reinforcing the threads, for example with some wood glue or special thread inserts. This significantly increases the durability of the joints.
Additionally, pay attention to high stresses on the connection points. With the Hemnes bed, frequent sitting on the bed frame side can increase pressure on the screw connections, which may cause problems over time.
