ᐅ What creative design ideas can I use for Ikea Besta units in small apartments?
Created on: 11 Aug 2022 09:13
Konnorle10
Hello everyone, I live in a small apartment and recently bought an Ikea Besta shelving unit to create some storage space. I am now looking for creative ideas on how to use the Besta in a multifunctional and space-saving way, without making the apartment feel cluttered or chaotic. I am especially interested in how to make this furniture piece both visually appealing and practical in small apartments, for example by combining it with other furnishings, using colors effectively, or through special arrangements and constructions. What creative ideas do you have for making the most of Ikea Besta in small living spaces?
Looking for a more detailed technical upgrade? The Ikea Besta series can be expanded with appropriate adapters and accessories, which offers creative possibilities, especially in small apartments. First: the basic units have a maximum load capacity of around 25 kg (55 lbs) per compartment, assuming careful assembly. If you plan to use the shelving partly as seating or to support a work surface, you should consider this load limit and, if necessary, reinforce the frame with additional bracing. Furthermore, dimensions are crucial, as Besta is available in widths of 60 cm (24 inches) or combinations of 120 cm (48 inches), with depths of 40 or 60 cm (16 or 24 inches). Smaller rooms benefit from the 40 cm (16 inches) depth variants, which still offer good storage space through practical internal organization. By fitting doors with adjustable hinges and magnetic closures, you can visually enhance the surfaces while also reducing noise. Finally, I recommend considering decoupling the modules during assembly using felt pads or sound-absorbing pads to prevent the shelving from resonating on the floor, especially when placed on laminate flooring.
As an addition: The Besta system is very versatile in terms of appearance. For small rooms, it is advisable to choose fronts in white or pastel tones, as these colors visually open up the space. For a modern look, matte finishes can be selected, which reflect less than high gloss, maintaining a calm atmosphere. It is also possible to line individual compartments with decorative wallpaper or vinyl foils—creating a subtle highlight without compromising the clean lines of the furniture. This is especially useful when the Besta is used as a room divider. Additional lighting, such as LED strips, can be discreetly installed to conceptually enhance the furniture.
I’d like to suggest a casual idea: use Besta units as a base for a small bar or a flexible snack area – especially if your apartment has limited space for a dining table. You can place the top part on stoppers with a mounting plate, add a few stylish bar stools next to it, and you’ll have a multifunctional gathering spot that also serves as storage for drinks and glasses. Want a colorful interior highlight? Paint the back panel in a bold color or apply sparkling foil to liven up the space. This way, the shelving becomes a conversation piece without overwhelming the room.
Katan schrieb:
Use Besta modules as a base for a small bar or a flexible snack area – especially when the apartment has little space for a dining table. Interesting approach! This shows how versatile the system is. I would like to point out that stability of the elements is particularly important when used as a bar, since frequent movement and loads can otherwise cause damage. A combination of creativity and technical know-how is therefore advisable to ensure long-lasting enjoyment of the furniture.
