ᐅ What connection options are available for Ikea Hemnes desks?
Created on: 17 Dec 2024 08:43
renzo40Hello everyone, I am planning to get an Ikea Hemnes desk and want to make the most of it, especially regarding connectivity options. Since I need to connect quite a few devices like a monitor, laptop, printer, and other accessories, I’m interested in what connection options are generally available for Hemnes desks or can be usefully retrofitted.
Are there specific solutions, such as integrated cable channels, USB hubs, power strips, or options for tidy cable management that work well with the desk’s design? Any advice on attachments or extensions that are suitable for neatly and invisibly storing chargers, adapters, or extension cords would also be very helpful.
If anyone has experience with modifications or practical adjustments on Hemnes desks, I would appreciate detailed tips!
renzo40 schrieb:
Since I want to connect quite a few devices like a monitor, laptop, printer, and other accessories, I’m interested in what connection options are generally available or can be reasonably retrofitted for the Hemnes desks.The Hemnes desk from Ikea does not come with built-in electrical connection options — meaning no included power outlets or USB hubs. It is simply a plain wooden desk without any cable management features. However, there are many ways to upgrade it.
First, I recommend focusing on cable routing: using Velcro straps, cable ties, and cable channels that can be mounted under the tabletop. This helps keep cables neatly organized. It’s important to choose attachment points carefully to avoid permanently damaging the wood structure.
Regarding power strips, there are practical options with mounting clips or screw mounts that can be discreetly attached underneath the desk. For USB connections, standalone hubs make sense; these can be placed on top of the desk or also mounted underneath.
If you want to connect many devices, I suggest a surge-protected power strip. You can also charge power adapters on this – ideally ones that are as flat and compact as possible.
Mechanically, the desk can be modified with drill holes or cable grommets with covers to guide cables neatly downward and prevent interference. However, be aware that Ikea wood panels can be sensitive to moisture and excessive stress.
Which exact devices are you planning to connect? That would help provide more specific recommendations, such as USB-C docks or separate power supplies.
Filippo schrieb:
The Hemnes desk from Ikea does not come with built-in electrical connections — so no included power outlets or USB hubs.I would like to summarize this more clearly to keep it organized for everyone interested:
- Basically: Ikea Hemnes desks are traditional wooden tables without electrical outlets or cable management features.
- Adding connections afterwards:
- USB hubs: USB-C or USB-A hubs can be attached on top of or underneath the desk surface.
- Power strips: best mounted under the tabletop with screws or hook-and-loop fasteners.
- Cable ducts made of plastic or metal: well-suited for organizing multiple cables together.
- Cable grommets: holes you drill yourself with covers to neatly route cables through the desk.
- Tips:
- Be very careful when drilling to avoid damaging the desk.
- Take measurements in advance and plan the positions.
- For a neater look, small clips or holders can be used—often not included by Ikea and should be purchased separately.
- Ergonomics:
Depending on how many devices you connect, it can also be practical to have a USB charging station with fast charging capability on the desk, to conveniently charge your laptop or smartphone.
If anyone has a step-by-step illustrated guide for retrofitting, that would certainly be helpful. Otherwise, just work carefully step by step—good planning is key.
renzo40 schrieb:
Are there any special solutions, such as integrated cable channels, USB hubs, power strips, or options for neat cable management that blend well with the desk’s design?To add to the previous contributions:
The Hemnes desk does not come with integrated cable channels or ports by default. Due to its classic wood appearance, cable management solutions made from subtle plastic or wood-look materials tend to fit better than visible plastic options in bright colors.
For power strips, I recommend flat strips with mounting clips that can be discreetly installed under the tabletop. There are also slim USB panels that can be mounted on the back or underside of the desk, simplifying device storage.
Cable grommets with covers made of stainless steel or plastic can be installed into the desktop in a few simple steps, provided you have the necessary tools. It is important not to damage the material, especially when working with the MDF wood board or veneer surface.
Conclusion: The Hemnes desk has no factory-installed connectivity options, but there is a wide range of compatible accessories for power outlets, USB connections, and cable management. Proper planning and choice of materials ensure an attractive and practical solution.
