Hello everyone, I am looking for targeted cleaning tips for IKEA Brimnes furniture. I’m particularly interested in effective methods to gently yet thoroughly clean the surfaces without damaging the coating or the material texture. Which cleaning agents are especially suitable, and which ones should be avoided? Are there any tricks for removing common stains or dust buildup that often occur on this type of furniture? I would appreciate it if you could share your experiences, including advice on regular care and maintenance. Thanks in advance!
Lutosan schrieb:
Which cleaning agents are especially suitable, and which should be avoided?Honestly, I think the hype around so-called "specialty cleaners" for furniture is a bit overrated. For Brimnes, I simply recommend a damp microfiber cloth and mild soapy water—nothing more. Anything beyond that is often just a way to make money or might even cause more harm than good. So why make it complicated when simple works best?
Hello Lutosan,
I’m happy to help you find the best cleaning method for your Brimnes furniture. The furniture is made from a combination of coated wood-based materials, which can be damaged by moisture and harsh cleaners.
I recommend the following care steps:
- Wipe regularly with a soft, slightly damp cloth.
- Avoid abrasive cleaners that could scratch the surface.
- For stains, use a mixture of warm water and a small amount of dish soap.
- Stubborn stains, such as ink or cosmetics, can be gently removed with a rubber eraser.
- Always dry the surface thoroughly after cleaning to prevent swelling.
If you have specific stains, I’d be glad to assist you further.
zarlu schrieb:
Why make it complicated when simple works best?That sounds reasonable in principle, but I wonder if this overlooks aspects like long-term material aging. A damp cloth might be enough in the short term, but regular maintenance using mild cleaning products could help protect the surface from microcracks.
Also, is there any evidence that products specifically marketed for coated furniture are actually harmful? Or is this more a marketing claim? I would appreciate well-founded information before dismissing this outright.
Can anyone share validated insights from experience or studies?
flo-Theres24 Sep 2022 12:38Hello everyone, regarding the question of material care:
Brimnes furniture is made with melamine-coated wood-based panels, which are quite durable. However, regular cleaning with a damp cloth, without any solvents, does no harm. For maintenance, I recommend mild furniture care products based on wax, specially designed for laminate surfaces, to keep the surface slightly flexible and to fill in small scratches.
Avoid abrasive cleaners or aggressive chemicals such as acetone or alcohol, as these can damage the surface.
For regular dust and dirt removal, a microfiber cloth with lukewarm water and a mild dish detergent is completely sufficient. For tougher stains, gentle treatment with a sponge is possible, but always with care.
This way, the surface will be preserved in the long term.
