ᐅ What maintenance guidelines apply to IKEA Hemnes furniture during the summer?
Created on: 2 Jun 2021 14:37
kla-pa
kla-pa
2 Jun 2021 14:37
I recently bought a Hemnes piece of furniture from IKEA, and since temperatures here often get quite high in the summer, I’m wondering what specific care recommendations apply to Hemnes furniture under warm conditions.
I know that solid wood can be sensitive to moisture and heat, so it’s important for me to understand how to best protect and maintain my furniture to avoid cracking, warping, or drying out.
Are there any special cleaning tips or treatment suggestions, such as oiling, waxing, or dusting, that I should follow during the summer?
I’m also interested to know if direct sunlight and fluctuations in humidity can cause significant damage and how I can prevent that.
Thanks in advance for your help!
kemads46
2 Jun 2021 16:09
Hello kla-pa,
Your question about care instructions for IKEA Hemnes furniture in summer is very relevant, especially because of the solid wood used in Hemnes. Here is a structured overview of what to keep in mind:
- Avoid direct sunlight: Solid wood Hemnes furniture should not be exposed to strong sunlight for prolonged periods, as UV light can cause the wood to fade and dry out.
- Control humidity: Humidity usually increases in summer, which affects solid wood. Too much moisture can cause swelling, too little can dry out the wood. An ideal humidity range is about 40-60% relative humidity.
- Cleaning: Wipe regularly with a dry or slightly damp cloth; do not use harsh cleaners. For stains, use a mild wood care product.
- Treatment: One to two times a year, you can treat the furniture with special wood oil or wax. This protects the surface and keeps the wood flexible.
- Temperature: Avoid strong temperature fluctuations, for example by placing furniture near radiators or air conditioning units.
In summary, regular gentle cleaning combined with occasional care using oil or wax is recommended, as well as avoiding direct sunlight and excessive moisture.
If you need more specific recommendations, I can suggest a care routine for you.
Danial
2 Jun 2021 18:21
kemads46 schrieb:
Avoiding direct sunlight: Hemnes solid wood furniture should not be exposed to strong sunlight for extended periods
That’s a valid point. However, I wonder how significant the effect really is on well-finished IKEA furniture?
kemads46 schrieb:
Ideal humidity levels are around 40-60%
Maintaining such consistency during summer is challenging, especially in unheated apartments. Isn’t the Hemnes series fairly resilient to normal fluctuations?
I think it would be helpful to gather feedback from users who have actually used Hemnes furniture over multiple summers. Theoretical care instructions are useful, but how does it hold up in everyday situations? For example: Has anyone noticed any damage caused by sun exposure or humidity?
I would appreciate more concrete user experiences.
nojaus
3 Jun 2021 09:47
I can share my personal experience: I have had a Hemnes bedside table in my bedroom for two years now, which often receives direct sunlight through the large window front in summer.
What I’ve noticed is that although the finish becomes slightly duller from the sun, there are no cracks or deformations. I make sure to dust it regularly with a soft cloth and occasionally treat it with a protective oil.
I believe that with the right care and a bit of caution, the furniture is quite durable. However, you should definitely avoid standing moisture and prevent drafts combined with humidity, which I have taken into account given the wood’s origin.
So here is a practical example.
kemads46
4 Jun 2021 11:56
Danial schrieb:
I think it would be helpful to also request experiences from users who have actually used Hemnes furniture for several summers.
I agree with this and would like to add: From a technical perspective, Hemnes is well protected by its surface treatment. However, its durability always depends on the environment.
In addition to my previous response, I recommend the following care routine specifically for the summer:
- Wipe down every 3 months with a damp microfiber cloth to remove dust that can otherwise cause fine scratches.
- Treat once a year with furniture wax or oils that create a natural protective layer.
- Avoid water puddles on the surface and gently wipe off any moisture that gets on it.
- Use window blinds or curtains when the sun shines intensely on the furniture.
This protects the wood and prevents damage that can become frustrating over time.
It also helps to monitor the indoor conditions, perhaps with a hygrometer, to keep track of the actual humidity levels.
