ᐅ What can you do if IKEA HEMNES drawers are sticking?
Created on: 8 Jul 2023 07:39
O
ONGOLI
O
ONGOLI
8 Jul 2023 07:39
I have a problem with the drawers of my IKEA Hemnes dresser model. Some of the drawers stick quite a bit when opening and closing, which makes everyday use really frustrating. I suspect the cause could be either incorrect assembly, warped runners, or drawers loaded too heavily, but I’m not sure.
My questions for the community:
- What are the most common specific causes of sticking drawers in Hemnes furniture?
- Are there proven methods or simple tricks to fix the problem on your own without having to take all the drawers apart?
- How about maintenance or adjustment of the drawer runners – is it really worth doing?
- Are there differences between older and newer Hemnes models that could affect drawer sticking?
If anyone has experience with similar issues or practical tips on how to proceed, I would greatly appreciate a detailed response. I want to keep the furniture as original as possible and avoid buying replacement parts unless absolutely necessary.
Thanks in advance!
KNUTGI
8 Jul 2023 11:46
Hey ONGOLI,
“I know exactly what you mean when you say ‘some of the drawers stick quite a bit when opening and closing’—it’s like my HEMNES has developed new quirks! 😄
First off: this often happens because the drawers are loaded too heavily or unevenly. That can easily throw the sliding mechanism off balance, especially if the slides are made of wood or MDF, which can expand or contract with moisture and temperature changes.
My advice would be:
- Gently remove the affected drawer
- Check if the sliding rails are clean and undamaged
- Lightly treat the edges of the drawer rails with fine sandpaper or a very light oil (careful not to use too much!)
Sometimes a small adjustment of the screw on the sliding rails helps a lot—you can achieve quite a bit with just a tiny turn.
If you’re a bit handy, I’d say it’s definitely worth trying these steps with a HEMNES before thinking about replacement parts. Good luck and best regards from a little furniture whisperer! 😉
Gafiel
9 Jul 2023 14:03
Hello ONGOLI,
Regarding your issue with the tilting HEMNES drawers, I would like to go into a bit more technical detail. The sticking often results from a combination of the following factors:
- Uneven loading of the drawers, which can cause warping of the carcass or drawer front
- Dirty or damaged runners – especially with wooden runners, even small amounts of dust can create significant resistance
- Missing or incorrectly installed stops that precisely guide the drawer in and out
- Warping caused by moisture affecting wooden parts
A systematic approach would be:
1. Completely remove the drawers and check for damage
2. Carefully inspect the runner tracks for any signs of deformation or dirt
3. Lightly sand down the rubbing areas with fine sandpaper (grit 240 or finer) – then remove any residues
4. As a test, treat with dry graphite powder or a lubricant specifically designed for wooden runners – avoid oils that can leave stains!
5. Check that the drawer sits flush and that no edges are rubbing – if necessary, make slight adjustments or use installation aids
Regarding your point about older versus newer models: IKEA has indeed switched some HEMNES drawers to metal roller runners in recent years, which are generally more durable. The older models with wooden runners are more sensitive to weather effects and loading.
A quick question: How old is your piece of furniture, and what type of runners are installed? That will be very helpful to provide accurate advice.
I look forward to your reply!
Layla
10 Jul 2023 09:27
ONGOLI schrieb:
Some of the drawers stick quite badly when opening and closing, which makes everyday use really annoying.
That can be really frustrating, especially when you appreciate furniture that you have carefully chosen and assembled yourself. I experienced something similar with my HEMNES dresser and hesitated for a long time because I thought the problem might resolve on its own or it would be a warranty issue.
In the end, this helped me:
- Gently removing the drawers and cleaning the tracks, as fine dust and small wood chips had actually accumulated in mine.
- Then I polished the tracks with a dry cloth—no lubricants, because my drawers are made of wood and lubricants could actually damage the wood.
- I also made sure not to overload the drawers too much, which makes a big difference.
I wanted to encourage you not to underestimate the issue but also to remember that often small, careful adjustments can bring a great deal of relief without having to send the entire piece of furniture to a workshop.
How are you coping so far with the usage limitations? Have you taken any parts apart yet, or are you keeping it as is for now?
