ᐅ What repairs can I do myself on IKEA Hemnes furniture, and when should I seek professional help?
Created on: 16 Jun 2015 07:23
Tarix67
Hello everyone, I recently bought some furniture from the IKEA Hemnes series – including solid wood dressers and nightstands. Now I’m wondering: What kind of repairs can I realistically do myself if these Hemnes pieces get damaged or start to become wobbly? And at what point should I call in a professional, like a carpenter or woodworker? I have basic DIY skills—I can drive screws and assemble furniture—but I’m unsure when it comes to wood repairs, more significant damage, or possibly replacing parts. Maybe some of you have experience with what’s doable for amateurs and which mistakes to avoid? Thanks in advance!
glapu
16 Jun 2015 13:44
In short: You can tighten screws and fix small scratches yourself. For wood cracks or unstable joints, it's better to call a professional. The material is sturdy but not a precious resource.
janeo
16 Jun 2015 15:29
Guyju schrieb:
- If load-bearing elements are broken, or if you want to structurally modify the furniture, that’s usually a job for professionals.
I agree with that, but there is an interesting question here: Although Hemnes is made of solid wood, it is not an exclusive brand with specific repair guidelines.
My thought is whether it is possible to reduce stability through DIY repairs (perhaps using different materials or techniques) because the construction is not fully understood. For example, simply adding screws in different places when you can no longer replicate the original design.
Therefore, I believe the decision to seek professional help should be based not only on aesthetic concerns but also on safety criteria.
Tarix67, have you encountered specific cases where you were unsure?
relupa
16 Jun 2015 18:34
I can fully understand how unsettling it can be, especially when you want to care for and repair your furniture. Your doubts are completely understandable.
Perhaps this will help: proceed step by step, document what you do whenever possible, and always set a clear limit for yourself about when to stop and ask someone for help.
I have personally treated small surface scratches on Hemnes furniture several times and have always been pleasantly surprised by the results.
However, don’t hesitate to recommend professionals if you find that you can’t resolve an issue or if you lack the time. This often saves more frustration than trying to do everything yourself.
Tarix67
17 Jun 2015 07:11
Thank you all for the detailed and helpful responses!
In response to chentan’s question: So far, one corner of a dresser front has slightly split, and one leg of a bedside table wobbles a bit, probably because a screw is loose or the dowel is no longer secure.
I will first check the screws and probably treat the splintered area with wood filler. However, I am still concerned about the appearance—when it comes to Hemnes furniture, is it possible to treat these spots with color in a way that they hardly show? Or do you usually need to call in professionals who can refinish it properly?
Also, I would like to know if there is anything to be especially careful about when tightening the screws again, to avoid causing further damage to the wood.
Guyju
17 Jun 2015 08:33
Tarix67 schrieb:
I do have concerns about the appearance – is it possible with Hemnes to treat these spots in a way that makes them barely noticeable?
That is a very valid question! With Hemnes, you can use color-matched wood fillers or wax sticks that are specifically made for furniture in the IKEA wood tones. Important steps are:
- Lightly sand the damaged area beforehand.
- Apply wood filler with a putty knife and remove any excess material.
- After it dries, you can adjust the color using touch-up markers or furniture wax.
If you work carefully and patiently, the repair will be barely visible.
When tightening screws: Make sure not to overtighten to avoid tearing out the wood. Always insert screws straight, and if the wood threads are stripped, you can fix the issue using a larger dowel. If you are unsure, feel free to ask again!
LENNAU
17 Jun 2015 13:17
Tarix67 schrieb:
I would also like to know if there is anything to avoid when retightening the screws to prevent further damage to the wood.
Ah yes, I’ll add the following:
- Do not overtighten the screws, as solid wood can split or the threads can strip if over-torqued.
- It’s best to use a cordless drill with torque control.
- If screws are loose, you can carefully remove them and fill the holes with some wood glue and wood shavings – this provides better grip.
- Do not leave the furniture in damp rooms before repair, since moisture can cause the wood to swell and affect stability.
Good luck repairing your Hemnes furniture!
