ᐅ What can I do to make the drawers in Ikea BESTA units operate more quietly and smoothly?
Created on: 16 Aug 2019 09:13
Dausdeo
Dausdeo
16 Aug 2019 09:13
I have been using several drawers from the Ikea Besta system for a while now, which I actually find very practical. However, I have noticed that over time, opening and closing has become somewhat stiff, and the drawers rattle or no longer run as quietly and smoothly as they did initially. I would like to know what options are available to improve the quietness and ease of movement of the drawers. In particular, I am interested in tips for maintaining the drawer slides, suitable lubricants, or whether it is advisable to replace certain parts of the drawer mechanism. Perhaps someone also knows adjustment tips or small tricks that make the operation noticeably more comfortable without requiring major modifications. Overall, I am looking for practical solutions to make the drawers in the Ikea Besta system run quieter and smoother. Does anyone have experience with such optimizations?
Elijah42
16 Aug 2019 12:07
As a general rule, it helps to thoroughly clean the sliding rails first. Dust and dirt significantly affect their movement. After that, you can use a special silicone spray or a dry lubricant to improve the glide. Be sure not to use oily substances, as they attract dust. If the rails are damaged or bent, replacement would be advisable.
taotis53
17 Aug 2019 08:39
Elijah42 schrieb:
Basically, it helps to thoroughly clean the drawer slides first.
That is indeed a crucial point. In addition, I recommend checking during cleaning whether the ball bearings move freely or if they are blocked by dirt. A careful visual and manual inspection of the drawer components should definitely be carried out.
Furthermore, depending on the production year, different slide models may have been installed in Ikea BESTA units. Especially with older versions without soft-close, compatible accessories from the IKEA range can be used to improve functionality.
If optimization with spray lubrication is not sufficient, it is worthwhile to carefully adjust the drawer inserts and slides. Allowing a little play when fastening can significantly affect the smoothness of operation. IKEA assembly instructions can also be helpful in this process.
KIN42
18 Aug 2019 14:52
taotis53 schrieb:
A careful visual and manual inspection of the pull-out components is absolutely necessary.
Exactly. Additionally, I would like to offer the following tip: For Bestå drawers, a so-called soft-close mechanism kit can be retrofitted, provided that the existing runners are compatible.
This damping system ensures smooth closing and also significantly reduces rattling and sudden opening. The investment is especially worthwhile for frequently used furniture pieces.
Furthermore, proper load distribution in the drawer is important for easy operation. Drawers that are too heavy or unevenly loaded put extra strain on the runners and make movement more difficult.
lis64
19 Aug 2019 10:24
I can add: In addition to cleaning and lubrication, it helps to regularly check whether the drawers are properly aligned. If the drawer is slightly crooked, it causes unnecessary friction.
A smooth and easy movement can also be achieved by slightly readjusting the screws on the slides to optimize the operation.
