ᐅ What can I do if the doors of Ikea BESTA cabinets constantly rattle?
Created on: 21 Jun 2023 10:13
Jeson
Jeson
21 Jun 2023 10:13
Some time ago, I assembled two IKEA Besta cabinet units with doors. Unfortunately, the doors have been rattling continuously for a while now when lightly bumped or when there is a draft. The noise seems to be caused by too much play in the hinges or a lack of damping. The doors do close properly but do not sit firmly against the cabinet frame, which causes an annoying rattling when moved.
I have already adjusted the hinges slightly and tested whether reinforcing the seal on the frame improves the situation. However, the problem persists.
My question to the community: What can I do if the doors of IKEA Besta cabinets keep rattling continuously? Are there proven solutions or specific replacement parts that can reliably solve this issue? I look forward to concrete tips and shared experiences.
Ryder35
21 Jun 2023 10:47
usually it helps to tighten the hinges properly again and adjust the closing pressure setting. Sometimes the plastic dampers on the door stop are worn out and can be replaced. Take a close look at the hinge fastenings.
draleo
21 Jun 2023 11:18
Regarding the rattling issue with IKEA BESTA doors, the first step should be to check the correct alignment of the doors. The hinges generally offer adjustment options in three directions:
- Vertical: for height adjustment
- Horizontal: for depth adjustment
- Tilt: to achieve the correct closing angle
Persistent rattling may indicate that the door is not flush with the cabinet frame. It is recommended to systematically check the hinges and slightly tighten or loosen all screws until the door fits perfectly.
Additionally, the plastic dampers that cushion the door stop may be worn or displaced. Replacement or retrofitting options specifically for the BESTA series are usually available and easy to handle. If in doubt, small self-adhesive felt or rubber pads at stressed points can also help reduce the noise.
In summary:
- Precisely adjust the hinges
- Replace worn dampers
- Check if narrow seals or pads can reduce play
These measures are the most effective way to prevent persistent rattling.
Gloriagl10
21 Jun 2023 12:02
I had the same problem myself.
Part of my solution was to readjust the hinges. Sometimes they are set too loosely. If that is not enough, a small piece of foam rubber or felt between the door and the cabinet frame can stop the rattling.
Lotizar
22 Jun 2023 08:29
For a structured approach to permanently rattling BESTA doors, I recommend the following steps in order:
- Check whether the hinges are properly installed, ensure no screws are loose, and verify that the door is secured with even pressure when closed.
- If present, inspect the position and function of any damping mechanisms. These wear out over time and should be replaced if audible noises occur.
- Apply self-adhesive rubber or felt bumpers to the door’s contact surfaces or the corners of the carcass. These help absorb vibrating noises.
- Finally, if the fit is insufficient, the door can be realigned, possibly by slightly adjusting a hinge or repositioning the pins.
This way, potential causes can be systematically ruled out and the problem resolved. Replacing the hinges with high-quality, damped versions is also an option if the original mechanism is unsatisfactory.
jeix9
22 Jun 2023 13:57
Use small felt pads or self-adhesive rubber bumpers where the door meets the cabinet. This quickly and easily reduces rattling.
