ᐅ What can I do if assembling the IKEA PLATSA doors doesn’t work?
Created on: 17 Jun 2020 08:27
TausonGood morning everyone, I am currently facing the problem that the installation of the doors on my IKEA Platsa wardrobe just won’t work. The hinges cannot be properly attached, the doors hang crooked or don’t close properly. I have checked the instructions several times and am generally familiar with the assembly, but I am starting to get frustrated. Are there any special tips or common mistakes when assembling PLATSA doors that I should be aware of? Perhaps advice on door alignment or the correct handling of the hinges that goes beyond the IKEA instructions? Any tips would be very helpful, thank you in advance!
A common reason why PLATSA doors do not hang or close properly is usually incorrect adjustment of the hinges. These are generally adjustable in three dimensions – height, depth, and sideways. It is important to adjust the screws step by step and check the door’s position after each adjustment. Often, people try to adjust all screws at once, which makes the process more difficult.
Another point: be sure to check if the hinge drillings are exactly aligned. Carelessness here can cause crooked doors or insufficient clearance for the hinges to function properly.
Additionally, it can help to clean the guide rails on the door and the cabinet body if wood debris or glue residue has accumulated there.
Hey, that sounds really frustrating – but keep your spirits up! 🙂 I have assembled PLATSA doors several times myself, and what I’ve learned is that patience is key! It’s especially important to carefully follow every step of the instructions without rushing. That can be tough because you want to see the finished cabinet right away, but it’s worth it.
Also, I got a tip from an experienced friend to first loosely attach the doors with the hinges, then adjust the alignment, and only tighten all the screws at the end. This way, you can fine-tune the fit and avoid the doors sticking.
You can do it, just keep at it!
PECLARISSA17 Jun 2020 11:33Oh, IKEA PLATSA doors and their quirks... 😂 I totally get where you’re coming from! But hey, maybe this little tip will help: make yourself a cup of coffee 🥤, play some music, and then get started.
Seriously though: sometimes it’s all about the sequence! Many people unfortunately start with the hinge holes instead of connecting the door to the frame first. Keeping the screws slightly loose so you can easily adjust everything later also helps.
And if you have a second person to hold the door while you’re screwing it in—even better! That way you can quickly notice where gaps appear or if the door isn’t closing properly.
GAGRAHAM schrieb:
Also, I received a tip from an experienced friend to first loosely screw the hinges to the doors, then adjust their alignment, and only finally tighten all the screws. This way, you can fine-tune the fit better and avoid the doors sticking.Thanks for the encouragement! Loosely screwing the hinges did actually help me. After that, I checked and adjusted the alignment hinge by hinge. However, I have the issue that my doors wobble slightly—they are not firmly fixed to the frame, but rather rock a bit when touched. Could this be due to the way the hinges are installed? If so, what exactly should I check or adjust?
Regarding the issue of "wobbly doors" in the IKEA PLATSA series:
- First, check if all hinge fastenings are properly tightened. A loose hinge often directly causes wobbling.
- Also, inspect the position of the hinges on both the door and the cabinet frame. They must be perfectly aligned parallel.
- Use a small screwdriver to adjust the hinges in three dimensions:
- Height adjustment: move the door up or down.
- Side adjustment: shift the door sideways to ensure an even gap.
- Depth adjustment: make sure the door sits flush with the cabinet frame.
As a last resort, you can place a small shim (for example, a thin piece of paper) behind a hinge if the hinges are slightly misaligned. This might sound unusual, but it has often proven helpful.
