I recently purchased several pieces of furniture from the IKEA Hemnes series, especially dressers and nightstands. Unfortunately, I have noticed that some of them are quite wobbly, which raises concerns about their stability and long-term durability.
My question is: What can be done specifically to fix wobbly IKEA Hemnes furniture? I would like to know which methods or additional measures are recommended to significantly improve the stability, without having to completely disassemble or extensively modify the pieces. Tips on suitable tools, materials, or simple tricks to improve their steadiness would also be very helpful.
Are there common assembly mistakes that particularly cause this instability that I should avoid? Any helpful information on this topic is much appreciated!
AUSTINREN2 Apr 2021 15:24In addition to tightening the screws and using brackets, it has proven effective with Hemnes furniture to equip the points where the furniture contacts the floor with non-slip rubber pads. These prevent both sliding and slight rocking movements on smooth floors.
Another tip: During assembly, the back panel is often attached but not always properly aligned and secured. A straight and firmly installed back panel significantly improves resistance to tipping. If the back panel is only loosely nailed, stability issues may increase.
In summary, the key points for stabilizing IKEA Hemnes furniture are as follows:
- Fully and carefully tighten all screws.
- Strengthen connections with additional brackets or corner connectors.
- Use suitable wood glue or dowel adhesive in the existing joint holes.
- Ensure a level installation surface or compensate with shims.
- Reinforce or replace the back panel if necessary.
The combination of mechanical fastenings (screws, brackets) and adhesive reinforcements (wood glue) is one of the most durable solutions to reduce wobbling in the long term.
tudipi schrieb:
What can be done specifically to prevent IKEA Hemnes furniture from wobbling?I'm glad you're approaching the topic so specifically. I have Hemnes dressers and nightstands myself and use the following methods:
- Always tighten screws carefully with the appropriate tool; regular checks are worthwhile.
- For visible play in the connections, I apply wood glue sparingly into the screw holes to secure the parts permanently.
- To compensate for minor floor unevenness, I use adjustable furniture feet under the original legs.
- Make sure to align the back panel precisely, as it stabilizes the entire structure.
These measures noticeably increase stability for me without major modifications to the furniture. It remains a matter of patience, as materials can settle over time.
