ᐅ What assembly tips are there for IKEA PLATSA furniture?
Created on: 7 May 2021 10:23
Ronfi
Ronfi
7 May 2021 10:23
Hello everyone, I recently ordered some IKEA Platsa furniture and am now about to start assembling it. Since the system is modular and apparently offers various assembly options, I would like to know: Are there any specific assembly tips for the IKEA Platsa pieces to avoid mistakes, make the process more efficient, and ultimately achieve a stable and durable piece of furniture? Are there particular recommendations regarding the alignment of the modules, screwing them together, or securing them to the wall? I appreciate any practical advice that goes beyond the general instructions and that someone might be able to share from experience.
Thierryzar
7 May 2021 10:48
The stability of PLATSA largely depends on wall fixings, so do not skip them. Also, always install the modules on a smooth and level surface. Tighten screws firmly, but not too much, as the material can crack. Sort and check all parts before assembly.
Liduta
7 May 2021 13:07
I would like to add a few structural tips that are especially useful for the modular system PLATSA:
- Preparation: Before assembly, systematically lay out and check all individual parts according to the instructions. This helps prevent mix-ups.
- Alignment: Make sure to pay close attention to the alignment of the drill holes and dowels when connecting the modules; otherwise, they won’t fit together properly.
- Screws: Initially, tighten the screws only lightly to allow for adjustments in positioning. Only fully tighten everything at the end.
- Wall attachment: Always use the supplied brackets, even if the furniture stands on the floor. This increases safety, especially with taller modules.
Common mistakes often include screwing the modules together too early before the alignment is correct or underestimating the load-bearing capacity of the wall.
kibutar
7 May 2021 15:35
I want to go into great detail here because I find the PLATSA assembly to be very versatile, and technical details are often overlooked.
First, the material structure: The MDF panels that make up the PLATSA modules are sensitive to overtightening screws, which can cause swelling and splitting. Therefore, it is very important to control the torque with a Phillips screwdriver and, if necessary, tighten screws by hand.
Furthermore, I recommend the following steps:
- Use a workbench: It is best to assemble the modules on a large, clean table. This prevents scratches and provides better access.
- Connecting the modules: Use the included wooden dowels and connectors exactly as described. Incorrect insertion can quickly lead to a distorted assembly.
- Follow the sequence: For large systems, fully assemble the individual modules first before combining them into one unit.
- Wall mounting: Be sure to check the type of wall (e.g., drywall or solid wall) and use appropriate anchors, not necessarily only the ones provided.
Therefore, my question is: How many PLATSA modules have you planned exactly, and on what type of wall will they be placed? Then I can provide more specific advice regarding the installation.
Ronfi
8 May 2021 09:14
kibutar schrieb:
So my question is: How many PLATSA units have you planned exactly, and on what type of wall will they be installed? Then I can provide more specific advice on the installation.
Thank you for the detailed response! I am currently planning 3 modules, which I want to combine into a larger cabinet. The wall is made of solid concrete, so the mounting hardware should be suitable. The goal is a half-height cabinet wall with about 2 meters (6.6 feet) total height. Are there any special tips for this kind of combination regarding the connections between the modules? I also want to ensure that the cabinet wall remains straight and stable over time.
JAPLO
8 May 2021 12:42
When connecting three modules to form a built-in wardrobe, I recommend the following:
- Check each cabinet box individually for squareness before assembling. Small inaccuracies can multiply otherwise.
- Always use all the supplied connectors for the modules, as this increases stability at the joints.
- Do not skip wall fastening; especially the middle modules should be additionally anchored to the wall.
- When screwing the modules together, hold them slightly fixed (e.g., with clamps) to avoid misalignment between the elements later on.
By following these points, you should achieve a stable and straight built-in wardrobe.
