ᐅ What installation tips are there for Ikea PLATSA doors?
Created on: 22 Jul 2021 09:34
narehsan
narehsan
22 Jul 2021 09:34
Good morning everyone, I am currently planning to upgrade my Ikea Platsa cabinets with new doors and have several questions about proper installation. I am especially interested in any mounting tips for the doors to ensure a precise fit, smooth opening and closing, and to prevent any damage to the materials. What experiences have you had with door attachments? Are there any tools or aids that you would specifically recommend? Also, can anyone advise on how to best adjust the hinges to avoid misalignment? I look forward to your tips and tricks, especially regarding potential pitfalls or unexpected challenges during installation!
derrick34
22 Jul 2021 09:51
I would recommend aligning the hangers as straight as possible and testing whether the doors close evenly before final fixation. Use a suitable screwdriver rather than a cordless drill to avoid over-tightening.
Le_kin
22 Jul 2021 10:18
Regarding the topic "What assembly tips are there for Ikea PLATSA doors?" I would like to provide a comprehensive answer, as many points are relevant to achieving the best result in the end. First, for preparation: place all parts on a clean, flat work surface to avoid scratches and make assembly easier. It is important to align the hinges precisely before attaching them. Use the included adjustment mechanism in three directions (height, depth, lateral alignment). I recommend initially fastening the screws only lightly to allow for door adjustment before fully tightening them. A common pitfall is uneven screw tightening, which can cause warped doors. Therefore, use a Phillips screwdriver with a good grip and work in small increments. Additional tips:
- Check before assembly that all drill holes are correctly positioned, as some furniture allows only narrow tolerances.
- When installing edge seals or softeners, ensure they do not interfere with the door closing function.
- For heavy models, additional spot connections can help increase stability.
If you plan to assemble doors in larger quantities, it’s worth considering compatible aids such as installation tools or templates that enable faster and more precise installation.
How exactly do you plan the assembly? Which door models and finishes are you using?
derrick34
22 Jul 2021 11:05
Le_kin schrieb:
Use the included adjustment mechanism in three directions (height, depth, lateral alignment). I recommend initially screwing in the screws only lightly to adjust the door before fully tightening them.
To me, this is the most important tip. It helps prevent the doors from sticking or hanging unevenly.
Santi
22 Jul 2021 14:46
When installing PLATSA doors, always ensure that the hinges are properly seated in the groove. It is not helpful if the door rubs on one side afterward. Also, always tighten screws by hand first, then check and continue tightening.
meGreg
23 Jul 2021 08:12
I can only agree with what has already been said here: calmness and patience are key when installing the PLATSA doors. A small tip from my side is to do a test assembly without the doors on the cabinet beforehand. This way, you can get familiar with the hinges at your own pace, without the cabinet already being in place and everything under tension. And one more thing: when adjusting the doors, a small mirror can help to spot minor rounding deviations on the edges – which are otherwise hard to see once installed. This helps avoid frustrating rework.
