ᐅ What are common assembly mistakes made with Ikea HEMNES furniture?
Created on: 19 Jan 2020 08:37
Bararam
Hello everyone, I have assembled several IKEA Hemnes furniture pieces and noticed some common assembly mistakes—whether due to unclear instructions or minor oversights. I am therefore interested in learning which assembly errors typically occur most frequently with Hemnes furniture. It is especially important for me to know which mistakes during assembly have the most serious consequences, for example, incorrect installation of connecting fittings, wrong order of steps, or improperly inserted dowels that later cause stability issues. Who has experience with this and can provide specific advice so I can avoid these mistakes in future assemblies?
Bararam
20 Jan 2020 08:39
REPITAR schrieb:
Always follow the instructions step by step, sort the components before assembly, and screw in the dowels and screws carefully but tightly enough.
What exactly do you mean by "carefully, but tightly enough"? Sometimes I feel like the screws need to be tightened properly, otherwise the structure wobbles after assembly – but on the other hand, you don’t want to damage the wood. Are there any practical experiences or recommended torque ranges for this type of furniture?
KIN42
21 Jan 2020 09:17
That is a valid question. Although there are no official torque values specified for IKEA furniture, a commonly recommended practice is:
- Tighten screws until they are snug but avoid pressing in or damaging the surface.
- You can often feel it by the resistance: stop tightening when the screw becomes difficult to turn with the screwdriver.
- For dowel connections, pause briefly and check that everything is properly seated, as overtightening often causes cracks or deformation.
A calm approach pays off and helps prevent rework.
U
usbla
22 Jan 2020 11:45
KAMERON schrieb:
Drawer slides are sometimes installed incorrectly, either too high or too low, which affects smooth operation.
This is especially common with Hemnes furniture that has drawers. A useful tip is to first align the slides centrally before fixing them in place and to check for smooth movement with a slight clearance. Incorrect mounting of the rails can later cause friction points or prevent the drawers from closing flush.
