Some time ago, I bought a Malm bed from IKEA, and recently I’ve noticed that the bed has started to wobble. Especially when I move, I feel a slight instability that is not only annoying but also affects the comfort of sleep.
I have already checked if all the screws are tight, but the problem doesn’t seem to be caused by that alone. I’m particularly interested in understanding the possible reasons for the wobbling of my Malm bed. Is it often due to the construction? Or could it be material fatigue or incorrect assembly?
Maybe someone here has had similar experiences or knows common issues with this model? It would be great if you could also share tips on how to fix it, as I don’t want to completely take the bed apart without knowing exactly what to do.
Thank you very much in advance for your help!
Hello Kotumeo,
regarding the issue of wobbling on the Malm bed, there are indeed some important points you should consider. First, it is essential to carefully check all screws and connection points again. Even if you have already done this, I recommend tightening the screws with the appropriate tool, as they can loosen over time due to daily use.
If the screws are not the issue, the wobbling may be caused by the interaction between the slatted frame and the bed frame. Malm beds often use support strips or metal frames that can move if not positioned correctly.
You should also rule out uneven floors, since a lacquered laminate or parquet floor can affect stability. Leveling out the floor with furniture pads or small shims can help here.
If you have a headboard or footboard with crossbars, it can help to check their fit, as play can develop over time in these areas.
In summary: tighten all screws, check the support surfaces, and consider using small pads for added stability. This usually solves the problem for many users.
I hope this helps you!
Kotumeo schrieb:
I have already checked if all screws are tight, but the problem does not seem to be caused by that.
I would like to take a closer look at the issue of wobbling in the Malm bed, as in my experience there are several technical causes that should be checked systematically.
First: The method of assembly. Malm beds are often assembled using wood screws and wooden connectors. Especially the joints between the side panels and the footboard or headboard are prone to play, as wood can give slightly over time and may expand or contract.
Second: The use of dowels is common in IKEA furniture. If these are not inserted correctly or fully, it can significantly affect stability. Also, the absence of wood glue at the joints can lead to small movements.
Third: The support points for the slatted frame. There are differences between wooden support strips or metal brackets, which are often clipped in. These can become loose or may need readjustment over time. In the Malm bed, the supports can also fit somewhat loosely in the drilled holes.
This is an important hint—it’s worth taking a close look there and removing the slatted frame to check whether the support points are stable.
Fourth: Material fatigue. If your bed is older or has been moved frequently, the material itself, especially particleboard, can be more prone to cracks or deformation. Small cracks in the wood can become noticeable.
Finally, a question for you: Have you ever completely disassembled and reassembled the bed? A full teardown allows better inspection and tightening of the connectors.
I also recommend lightly filing any wooden strips that are tight and causing tension.
Ethan schrieb:
Malms often have support strips or metal frames that can move if positioned incorrectly.
Summary of Key Points:
- Wobbling often occurs due to loose screws or connectors. Regular tightening is essential.
- Missing or incorrectly installed anchors can significantly reduce stability.
- Uneven floor surfaces must be leveled with appropriate underlays to prevent rocking.
- Slat bed frame support points are often weak spots. Check if they are properly and securely positioned.
- Material fatigue, especially in chipboard, can appear as small cracks and affect stability.
A recommendation: Follow a systematic approach using a checklist:
1. Check and tighten all screws and connectors.
2. Remove the slat bed frame and inspect the support points.
3. Check the floor level with a spirit level and level if necessary.
4. Perform a visual inspection for material damage.
5. Complete disassembly and reassembly if problems persist.
This way, potential sources of error can be targeted and eliminated.
Domau0 schrieb:
Wichtig ist, das Lattenrost mal herauszunehmen, um zu prüfen, ob die Auflagepunkte stabil sind.
I would like to point out that while the previous comments have been helpful, the issue could also be viewed from a different perspective:
The Malm bed itself is not a high-end product but rather designed with cost-efficiency in mind. This means certain compromises in material selection and construction were made intentionally.
Exactly—that is the point: particle boards deform due to fluctuations in moisture or mechanical stress, which can cause looseness even on a microstructural level that cannot be fixed simply by tightening screws.
Therefore, I would suggest, in addition to mechanical checks, carefully inspecting the entire bed frame structure for any deformations or loose joint connections. Are any wooden edges rounded off or swollen? Are there visible deviations from the original shape?
Also, the joints could be reinforced with an appropriate adhesive (e.g., wood glue) if the assembly has to be taken apart anyway.
In summary: the causes need to be examined in detail—mechanical loosening is just one of several possible factors.
Are there any visible signs of wear or deformation on your bed, Kotumeo?
Paxton38 schrieb:
Material fatigue, especially in particle boards, can show through small cracks and affect stability.
