Hello everyone, I am currently looking into the topic of IKEA Malm drawers and would like to start a discussion: What are the most common issues with Malm drawers, especially regarding their functionality and durability? I am referring to both mechanical aspects such as the drawer slides, as well as load capacity and potential material fatigue. In everyday use, I have noticed certain weaknesses in my Malm chest of drawers that interest me since I am planning both repair attempts and an overall evaluation of the product. Are there any known weak points I should watch out for? Thanks in advance for your insights!
PeoDaniel10 Sep 2024 09:25Hello Sauchen4, the issues with Malm drawers usually arise from two main areas: First, the roller or sliding rail mechanism can become clogged over time with dust or material residue, causing the drawers to no longer operate smoothly. Regular cleaning and occasional lubrication with suitable silicone oil can make a significant difference. Second, the attachment points: the screws can loosen or come out due to mechanical stress, making the drawer wobbly or causing it to warp. Under heavier loads or improper storage, the particleboard edges can also fray, which reduces stability.
I would like to add that, besides the typical mechanical issues, a design limitation is often reached concerning material stress. The Malm drawers are primarily made from coated particleboard, which is affordable but also has its limits when it comes to moisture and heavy loads. The area around the drawer slides is particularly critical, as stress points occur there. For example, if the drawer is heavily and fully loaded, the connection between the front panel and the carcass can eventually crack or warp. There are also cases where the plastic rollers or gliders in the slides break, which then requires replacing the mechanism. Tip: If you plan to store particularly heavy items, retrofitting with metal drawer slides might be a good idea to improve durability and smooth operation. Are you thinking more about repairs, or are you planning to replace them altogether?
Paunon schrieb:
The sliding rails often get stuck That is exactly one of the issues that bothers me. PeoDaniel schrieb:
The rolling mechanism clogs up with dust or material abrasion Thanks, I wasn’t fully aware of that; I can start cleaning right away. @Dilen, thanks for your very detailed post! At the moment, I’m leaning more towards repairs rather than a complete replacement, also to better understand the mechanism. I find your advice about the metal guides interesting. However, regarding the load, I have to honestly say that it is usually not overloaded, yet I am already noticing slight deformations at the bottom of the front panel. Does this also apply to normal use over several years? What would be the typical wear pattern in such a case?
The classic issue with Malm drawers: they squeak or jam at the most inconvenient moments, usually when your hands are full around the house 😅. Honestly, a little WD-40 or silicone spray on the runners usually does the trick, and the front works smoothly again!
Sauchen4 schrieb:That can happen with the thinner particleboard; a few millimeters (inches) of deformation is quite normal, especially if the furniture is several years old. If it gets too warped, unscrewing, cleaning, lightly moistening (carefully!) and using a backing board to reduce tension can help. 🙂
slight warping at the bottom of the front
