ᐅ What are the most common mistakes when assembling IKEA Brimnes furniture?
Created on: 25 Feb 2020 08:23
jackpe
jackpe
25 Feb 2020 08:23
Hello everyone, I recently bought an IKEA Brimnes wardrobe and am currently trying to assemble it. I noticed that there are some steps in the assembly process that can easily lead to mistakes. I am particularly interested in knowing: What are the most common errors when assembling IKEA Brimnes furniture, especially when installing the drawers and back panels? Are there typical pitfalls that should definitely be avoided to complete the assembly without rework or damage? I would appreciate it if anyone with experience could share their tips or warnings.
Rashadmeo
25 Feb 2020 09:45
Oh, great question! I assembled my Brimnes wardrobe completely on my own last year. The most common mistakes I’ve seen are: - Drawer slides installed incorrectly, which causes the drawers not to open smoothly! - The back panel is often attached crooked or only partially fixed, which affects stability. It’s important to take your time and tighten all screws properly. If you do this carefully, everything will work perfectly! 😊 If you have specific problems with the drawer assembly, just get in touch again – I have some tips for that!
anno58
25 Feb 2020 11:02
Good morning, jackpe! I completely agree with Rashadmeo and would like to add: One of the biggest mistakes when assembling Brimnes cabinets is inaccurate alignment of the side panels and the bottom panels. You should first fit all parts together without screws and check multiple times to ensure everything fits perfectly. This prevents later adjustments, which often cause damage. Using the right tools is also crucial – a cordless screwdriver with torque control can help avoid over-tightening the screws. Also, the back panel is important for stability – it should be attached flush and fully across the surface. Good luck!
mesila
25 Feb 2020 13:14
Hello jackpe, I would like to provide a somewhat structured response here, as I have assembled several Brimnes furniture pieces and encountered common mistakes: - Incorrect assembly order: It is important to follow the instructions step by step. Skipping screws or parts quickly can cause problems later, especially with drawer slides. - Screws not being driven in far enough or being over-tightened, which can cause the chipboard to split. - Assembling the drawer boxes incorrectly (e.g., inserting tabs the wrong way), especially regarding the drawer runners. - Not attaching the back panel centrally or securing it in only a few spots, which significantly affects stability. Tip: After each major section, slightly adjust the furniture and check that everything is aligned properly. If you like, I can send you a short checklist.
Tobias
25 Feb 2020 16:07
In short: Pay close attention to the alignment of the drawer slides. Many people install the slides on the Brimnes model a few millimeters (inches) off, which results in uneven movement. Also, make sure to attach the back panel perfectly straight and completely; otherwise, the furniture can become unstable.
FAZAR
26 Feb 2020 07:51
Hello jackpe, I want to go into some detail because there are a few technical aspects that need attention, especially with the IKEA Brimnes: The wardrobe is mainly made from particleboard, which means the material is not very flexible. There are several potential sources of error here: - Over-tightening screws: particleboard can crack easily if you apply too much force. - The connection system using Minifix connectors is critical in the Brimnes: if the connectors are not inserted precisely into the drilled holes, they can become misaligned, which later causes stability issues. - Also, I recommend loosely fixing the drawer runners with screws first, then using a spirit level and a tape measure to check their accuracy before fully tightening them. - The back panel should be fixed everywhere with small screws or nails because if it is installed crookedly, it puts uneven stress on the structure. I have a question for you: Have you been able to check if the parts are well prepared and not warped? This is an important prerequisite to avoid mistakes during assembly.
