I am currently working on assembling the BILLY bookshelf and would like to know from your experience what the most common mistakes are when putting this piece of furniture together. I am especially interested in areas where many users tend to be careless or steps that are often misunderstood, as I want to avoid having to take everything apart again at the end. Perhaps you can also share typical pitfalls when handling the individual parts or when using the included tools. I look forward to your answers!
Hello Forest,
to address your question, I would like to give a brief overview of the most common mistakes when assembling BILLY.
1. Incorrectly positioning the back panel: Many people insert the thin back panel the wrong way, which causes it not to fit properly or makes the shelf unstable.
2. Mixing up screws: Because there are different screw types in the set, the wrong screws are often used in certain places, which affects stability.
3. Shelves installed backwards: The boards have an edge that should face forward. If installed the wrong way, it looks untidy and can affect functionality.
4. Insufficient pre-drilling: Although there are pre-drilled holes, sometimes too much force is applied, damaging the wood.
My advice: work in small steps and check that the parts fit correctly before tightening everything.
This happens often and leads to frustration. I hope this helps you!
Tatovin schrieb:
Sometimes the shelf board is installed upside down.
Hello Forest,
I completely understand that you want to know what to watch out for beforehand. BILLY might seem straightforward at first, but there are actually a few details that can cause stress in the end.
For example, I once installed the back panel the wrong way around – which was very frustrating because I had to take everything apart again. Also, sorting the screws correctly is important since they all look the same at first glance, but using the wrong screws means the shelf won’t connect properly.
I find it helpful to review the instructions carefully from time to time and not rush the process. Also, if something doesn’t fit properly, make sure to double-check that everything is aligned correctly before tightening the screws.
I can only agree with that—it really helped me as well. Good luck with your project!
kuben schrieb:
My tip: Work in small steps and check whether the parts fit properly before tightening everything.
