ᐅ What are the common causes of squeaking in MALM beds?
Created on: 6 Aug 2022 08:23
Blasi
Some time ago, I bought a Malm bed, and I noticed that it squeaks repeatedly, especially when I move or turn over. My specific question is: What causes squeaking in Malm beds? I have already checked that all the screws are tight, but the noise persists. Could it be related to the choice of materials, the construction, or the assembly? I would like to understand which factors influence this typical noise development in order to potentially find a solution.
LUISABEL
7 Aug 2022 08:31
Josefane schrieb:
Are there any proofs that climate is the main factor causing squeaking?
Yes, studies on wood-based materials show that fluctuating humidity can affect their dimensional stability. While particle boards are more resistant than solid wood, prolonged changes can still cause slight swelling and shrinking, which may affect screw connections. However, I agree with you that the main factor remains the mechanical fastening.
LOGEMIN
7 Aug 2022 09:42
For better analysis, here is a brief guide to identify the causes of squeaking in Malm beds:
1. Tighten all screws with the appropriate Allen key or screwdriver.
2. Treat all moving joints with a dry lubricant (e.g., silicone spray) – avoid oily substances, as they can damage the wood.
3. Check that the slatted frame is securely in place and does not wobble.
4. Cushion contact surfaces with felt or foam pads.
5. Observe whether the noise occurs during specific movements (turning over, getting up, sitting down).
A systematic approach helps to quickly narrow down the cause.
farGlen
7 Aug 2022 10:12
Often, the issue is simply that the bed sides are not securely locked together. Check if the side panels are properly interlocked and tighten all connections. This eliminates 90% of the squeaking noises for me.
Paunon
8 Aug 2022 07:29
dijan schrieb:
Sometimes it also helps to insert felt pads or small fabric pieces at contact points
This tip is very useful. I recommend attaching felt quickly, as it effectively reduces noise at problematic contact points.
